Results 1 to 10 of 16
Thread: SRI Height
    Apr 2012
    Wexford
    Trim : SRI
    Engine : 1.9 150
    Mileage : 146,000
    Default SRI Height
    Does anyone know is there a difference in the height between the pre-facelift and the facelift SRI's? Had the womans car beside mine today, hers is PFL and mine is noticeably higher in the front so i measured just on my leg (didnt have measure tape to hand) and theres about an inch or a bit more difference from ground to wing arch. Mine has 225/45/17 and hers has the standard 215/50/17 so if anything that should bring mine slightly more to the ground than hers! The back is the same height on both cars. Her springs are not broke and look like standard ones and i put one new spring in mine 2 weeks ago and its an SRI spring so i know mine is standard..
    Apr 2012
    Wexford
    Trim : SRI
    Engine : 1.9 150
    Mileage : 146,000
    anyone?????
    North West - Assistant RO Woody's Avatar
    May 2012
    North West (Warrington)
    240 Post(s)
    Vehicle : Vectra C 3.2 Elite Estate Auto Facelifted
    Trim : Elite with loads of "Extras"
    Engine : 3.2 Z32SE
    Mileage : 94,000
    I think you're going to have to get a whole lot more specific fella. Exact spec of the cars being compared for starters (engine size, year, version etc) and then next, the measurements from centre hub to wheel arch on the cars being compared.
    After that, you will probably attract some input matey
    Apr 2012
    Wexford
    Trim : SRI
    Engine : 1.9 150
    Mileage : 146,000
    The 2 of them are SRI 150BHP, the womans is a 2005 Pre Facelift and mine is 2006 Facelift, the 2 of them are standard and the rears are same height but mine is over an inch higher both sides in the front!! Ill get a measure on them both tomorrow
    Apr 2012
    Wexford
    Trim : SRI
    Engine : 1.9 150
    Mileage : 146,000
    Ok just got measurments, from center of hub to wing,
    On my car the 2 front sides are 380mm
    rear left is 360mm
    rear right is 355mm
    on the womans car
    the 2 sides front are 360mm
    rear left 360mm
    rear right 355mm
    so 2 rears are the exact same but her front is 20mm lower than mine.......
    Apr 2012
    Wexford
    Trim : SRI
    Engine : 1.9 150
    Mileage : 146,000
    just measured a friends vectra cdti Design Pre facelift and hers is 380mm on the front both sides and 385mm on the rear both sides..
    Regular Member Niall83's Avatar
    Nov 2009
    Belfast
    Trim : Exclusive
    Engine : 18VVT Z18XER
    Mileage : 130k
    Could be broken springs or lowered, but why let it bother you?
    Regular Member john norris's Avatar
    Jun 2012
    lancashire
    Quote Originally Posted by Niall83 View Post
    because your bits have to be lower than the wifes
    could be shocks are worn on the wifes
    theres 15 mm between sri/sport and normal spec equipment weight no doubt will change that depending on how much extras there are
    Nov 2009
    Belfast
    Trim : Exclusive
    Mileage : 130k
    Ah just see now that the woman is the wife. Now I know why it bothers you lol
    Chelmsford
    I had to read that twice! I thought he was out measuring a random woman's car in a car park!
  1. height difference
    By 19CDTi in forum Vectra C / Signum Car Chat
    Last Post: 19th March 2011, 19:40
  2. Pedal height...
    Last Post: 18th October 2010, 14:12
  3. SRI ride height ??
    By Mickyboy in forum Suspension, Wheels & Brakes
    Last Post: 18th March 2010, 12:05
  4. Eibach height??
    By Steven in forum Vectra C / Signum Car Chat
    Last Post: 16th April 2009, 22:30
  5. Ride Height
    By paulhb in forum Vectra C / Signum Car Chat
    Last Post: 22nd February 2009, 10:28
vectra c 2 inch higher on the front
