Thread: Rough idling...and ideas please? : (
    New Member imthedaddy2010's Avatar
    Jan 2013
    Essex
    Default Rough idling...and ideas please? : (
    Evening all
    Got myself a Vectra Elite 3.2 (petrol) 2003, had a old 3 series that I swopped it for...took it on board knowing it had a few issues some of which I've sorted.
    Oil leak from rocker cover gasket at the rear, slight mis fire...changed the coil packs, the only issue I can't sort out, cause I'm no mechanic, is the idling one...from start in the morning it seems fine but when you set off for a journey and finally come to a stand still at a junction or roundabout the revs go up to about 2k and then slowly drop but never to a sensible level...if it does drop it drops to just above 1k and sometimes can go back up again.
    Also is there any way of getting an airbag light off or is it a case of auto electrician to read it?
    Any help would be greatful
    Cheers people
    Chelmsford
    Sounds like a gunked up throttle body to me. Plenty of info on here about how to clean it up (well, there is on the 1.8 and 2.2 litre engines, assume it's pretty similar to yours!)
    Assuming there isn't actually a fault with the airbag system (ie: light just on from car being started with an airbag unplugged) then it's a 2 minute job for anyone with Tech2 or the unmentionable PC based interface
    Feb 2012
    sheffield
    Vehicle : SIGNUM 1.9 CDTI ELITE
    Trim : ALL OPTIONS ELITE
    Engine : 1.9 CDTI 150
    Mileage : 140,000
    throttle body sounds good, maybe MAF sensor?
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    I would start cleaning throttle body.
    Regular Member biffbangpow's Avatar
    Jul 2012
    ferryhill
    Vehicle : vectra
    Trim : gsi
    Engine : 3.2
    Year : 02
    Mileage : 96k
    sounds very like mine , i changed my coil packs ,new plugs , cleaned the TB , done the TB to rear manifold pipe and cleaned out the manifold inlet hole !
    WHAT NOW ?
    can you change the TPS , without changing the TB ?
  1. 3.2 Veccy C rough Idling
    By maleko in forum Engine & Drivetrain
    Last Post: 4th June 2012, 08:32
  2. 3.2 Veccy C rough Idling
    By maleko in forum Vectra C / Signum Car Chat
  3. siggy 1.9 cdti rough idling
    By cockney16v in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2010, 11:47
  4. Rough Idling
    By iainm in forum Engine & Drivetrain
    Last Post: 12th August 2009, 22:51
  5. idling rough
    By briancdti in forum Vectra C / Signum Car Chat
    Last Post: 22nd November 2008, 16:21
