Results 1 to 10 of 24
Thread: Toyo Proxes 19"
    spoons
    Guest
    Default Toyo Proxes 19"
    OK, I've decided to give these Toyo Proxes a go when my Continentals expire... which will be soon at this rate..
    I've got 235/35/ZR19 at the moment.....
    Can I go for Toyo Proxes T1-R 245/35/R19 ???
    And what would be the consequenses for having a wider tyre... other than increased road noise...
    Cheers..
    South Central England
    10 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Well in that case, you would put your speedo out for starters.
    spoons
    Guest
    Quote Originally Posted by nutron View Post
    Hi Nutron
    Why would it put my speedo out ?? the profile is exactly as it should be.... just wider ??
    Wirral / ellesmere port
    10 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    i am also going for the toyo`s got gud price and they are on order
    for next week,i just need to find a spare alloy or if not then i`ll just go
    and buy a new1 to replace the kerbed 1
    [Ex]Admin Duncan's Avatar
    Quote Originally Posted by spoons View Post
    Hi Nutron
    No, it will be different. They are both 35% wall height of the width of the tyre, so on the 245 your wall height will be more so the overall diameter of the 245 will be more. Without hacking the figures into a tyre calculator I don't know the % difference. There was a link to one the other day, I'll see if I can find it.
    As for difference in feel/handling. They will feel more planted on corners, but you'll get a bit of an increase in tramlining and probaly, as you said, road noise.
    Also, I have a feeling 245/35/19 isn't a recommended size for Vx. I think it would need to be 245/30/19. Somebody will correct me if that's not the case.
    Edit: Found the link for the tyre size calculator
    Here's the figures for the two profiles....
    The 245/35s do have a larger sidewall and larger overall diameter - but by hardly anything. I was expecting it to be more for some reason. And the speedo difference isn't much to worry about either.
    I'd still check that the sizes are Vx recommended though - just to avoid any nasties.
    HTH
    Regular Member VectraV6CDTi's Avatar
    Wilts
    Got to be done Steve, think you'll be impressed. Sticks to the road like glue, hope they last though
    With regards to knocking the speedo out, mine has changed a bit going from 215/50s to 245/45. Checking with sat nav its reading about 2-3mph under what it was before. So 80mph on the speedo before was 77mph on the sat nav. Now its about 75mph. But at least I'll be able to go "faster" and not get caught for speeding
    Wilts
    Bl00dy heck, just looked at the price of these on blackcircles, for your size, 235, your looking at £163.50 for T1-R's and £182.65 for 245. Thats EACH!! (although you'll get 5% off if you use code: bc121 or 1E419645 or RRAF or dirtbox - one of them will work!)
    Cost me £187 for 2 last week!
    spoons
    Guest
    I'll probably just stick with the 235/35/19 as they are standard spec... and about £20 cheaper than the 245/35/19
    Will just wait now till summer time and I will get them changed over...
    10 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    I can get T1-Rs much cheaper than that, £118 including Vat fitted for 235/45 17R. There is no way it will cost you an extra £60 for the 19".
    The Toyo 888 only go upto 18" but the 295/30 ZR18 98Y only cost £200 and they cost £180 in a 235/45 ZR17 93W 2G. So your being way over charged!
  1. Toyo Proxes T1-R ?
    By matt2002 in forum Handling & Braking
    Last Post: 8th April 2010, 10:47
  2. tyre 235/35/19 toyo proxes,
    By mitch in forum Parts for sale
    Last Post: 11th January 2009, 18:07
  3. Toyo Proxes T1Rs
    By Smudger1 in forum Handling & Braking
    Last Post: 19th September 2008, 14:12
  4. Toyo proxes TR-1s
    By jontymo in forum Vectra C / Signum Car Chat
    Last Post: 25th February 2007, 12:32
  5. Toora 19" Alloys with Toyo Proxes ...
    By Bainie in forum Parts for sale
    Last Post: 5th July 2006, 11:59
