Thread: 150 cdti valve seals
    Feb 2012
    sheffield
    Vehicle : SIGNUM 1.9 CDTI ELITE
    Trim : ALL OPTIONS ELITE
    Engine : 1.9 CDTI 150
    Mileage : 140,000
    Default 150 cdti valve seals
    Hi all,
    I have got my car running quite well now except for a cloud of smoke on start up in the morning, it clears straight away but there is quite a lot initially when cold.
    Question is, can the valve seals be changed without removing the head?
    Cheers.
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    what colour is the smoke? Could just be unburnt diesel.
    Feb 2012
    sheffield
    Mileage : 140,000
    Hi,
    smoke is black mostly, maybe a little grey mixed in, it really only does it on the turn of the key then clears 4 seconds later.....engine revs are rough for this time but not horribly
    Middlesex
    Trim : SRI
    Mileage : 100k
    Valve seals will be blue smoke - i.e. oil burning.
    Black ish sounds like Diesel to me.
    Are you allowing the glow plugs to warm before firing? Could be that the glow plugs are on there last legs.
    Feb 2012
    sheffield
    Mileage : 140,000
    yeah glow plugs were changed a little while ago.........I suppose the smoke is a bit blueish/black, after all the work I have done over the past few weeks I am pretty sure it is valve seals....its done 137,000 miles now so am expecting it.....after start up it runs 100% perfect all day!
    Quote Originally Posted by bladeage1 View Post
    Hi all,
    Cheers.
    there are ways to replace stuff in the head without removing the head itself.
    if you have an air compressor you can buy an attachment for your air line that screws into the glow plug socket. You can then pressurize the cylinder which keeps the valves closed allowing you to compress the spring with an overhead type spring compressor, remove the spring and ultimately remove and replace the seals.
    Not sure if this can be done on the 150?
    I've never had to do this practice. all valve work I've ever done has been with head off.
  1. Valve stem seals. Do they go on the Vectra C CDTI
    By smiley-sri in forum Vectra C / Signum Car Chat
    Last Post: 22nd November 2019, 21:11
  2. valve stem seals
    By Madmarky01 in forum Vectra C / Signum Car Chat
    Last Post: 7th April 2012, 16:51
  3. Z22SE Valve Stem Oil Seals
    By a15nma in forum Engine & Drivetrain
    Last Post: 28th November 2011, 23:00
  4. Replies: 5
    Last Post: 17th January 2011, 09:12
  5. Replies: 0
    Last Post: 30th September 2010, 19:11
vectra cdti valve spring compressor
https:www.vectra-c.comforumshowthread.php182588-150-cdti-valve-seals
