A few weeks ago i had the rear discs & pads done on my 2005 Vec, the mechanic put the pads in back to front so at the time I was getting a rattle so I changed them round a hey presto rattle gone.
Thing is now i have the rattle back on 1 side so i took the inside pad out today and stretched the spring out a bit to make sure its holding the pad nice and tight.
It was fine for about an hour(on my 2 hour commute home) and then started again but now it seems to make the rattle noise on each rotation of the wheel as well as over bumps.
Has anyone experienced the noise on rotation before and also does anyone have a solution other than trying a new set of pads.
