Thread: High consumption / initial checks?
    Feb 2013
    Oxford
    Trim : Elegance
    Engine : 2.2
    Default High consumption / initial checks?
    Hi,
    Have just bought a 2003 Vectra 2.2 petrol auto. 93k on the clock and last service was 2010.
    It seems a little thirsty. As I'm unsure exactly when things were last done, I'm going to change oil and air/fuel/oil filters and maybe clean the throttle. What else could I check to see if I can improve the MPG (I'm not sure of reported MPG as the display is corrupted so awaiting second hand replacement)
    Edit:
    Also, when cold and slowing down I sometimes feel a noticeable jolt which goes away after a couple of miles. Anything to worry about? Should I check/replace auto gearbox oil?
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    What are you getting, and what sort of driving? The 2.2 is thirsty. Though a full service never does it any harm.
    Just to add I think the display is just that, a display. Changing it wont have any effect on the information it displays
    Feb 2013
    Oxford
    Trim : Elegance
    Engine : 2.2
    I brimmed it a couple of days ago and it may not be as bad as I suspected, approx 170ish miles on half a tank so far..
    The display itself seems knackered. Only the lower half shows and even that seems 'smeared'. I can just about see the remaining miles counter and it seems all over the place - yesterday, it was going down by a mile every couple of seconds and then was back up again later. (I know replacing the display won't fix the numbers but at least I'll be able to see them)
    Just to make matters worse, I tried opening the bonnet earlier to check the coolant level (had the warning light yesterday so topped up.. hopefully not a gasket issue!) and the lever doesn't seem to be doing anything. Am going to try pulling the cable with plyers but it may have popped out of the latch. From what I've seen, it's a right ***** to open and it's fairly likely I'll have to break the grill?
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    24 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Has the lever come out of its mounting in the car?....
    Feb 2013
    Oxford
    Trim : Elegance
    Engine : 2.2
    The lever works - it moves but there's no tension on the wire. I unclipped the wire from the handle and tried pulling with pliers - it only comes out a couple of inches and then doesn't come any further so it's not snapped but might have popped out of the release mechanism?
    Nov 2007
    DERBY
    24 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Ahhhh...you cant get access to the lever/release mechanism from underneath the car..not easy without access to a ramp etc but is achievable
    Feb 2013
    Oxford
    Trim : Elegance
    Engine : 2.2
    Whoop! I got it open!
    Just needed to use a long drill bit poked through the grill. I even had a hammer, chisel and stanley knife out ready to cut my way through the grill. Am glad I persevered.
  1. why the high fuel consumption?????
    By richje100 in forum Engine & Drivetrain
    Last Post: 27th March 2011, 20:28
  2. high oil consumption
    By bombai in forum Engine & Drivetrain
    Last Post: 15th February 2011, 23:14
  3. Initial lumpy idle and slow initial throttle response?
    By Drazek in forum Engine & Drivetrain
    Last Post: 3rd January 2010, 23:48
  4. high consumption of diesel ?????
    By martinka1702 in forum Engine & Drivetrain
    Last Post: 16th February 2009, 11:31
  5. oil consumption too high???
    By Nickzx6r in forum Vectra C / Signum Car Chat
    Last Post: 2nd April 2007, 21:19
