Results 1 to 10 of 10
Thread: wont go past 4k after sensor change
Hybrid View
    Regular Member coooky's Avatar
    May 2011
    washington
    Default wont go past 4k after sensor change
    i changed the temperature sensor on my car and the engine managment light is still on and the car wont go over 4k revs and the engine is really lumpy on tick over and just isnt right
    when i took out the old sensor it was bone dry i have unscrewed the new one and there is fluid there as it seeped out a little
    any ideas ??
    May 2011
    washington
    faulty sensor was advised changed that and its still not working
    was advised if it wasnt the sensor it could be the wiring
    once this is fixed the car is gone its been nothing but a money pit and i will definitely not be getting another
    Hanging Heaton
    35 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    Any splits in the pipes?
    May 2011
    washington
    not that i can see it was getting dark once i had fitted the second sensor i will have a look tomorrow
    all the car does is eml comes on and it goes into limp mode i unplug the sensor the fan kicks in plug it back in the engine runs fine for about 30 seconds then starts jumping about again
    thanks for the advice
    May 2011
    washington
    one more thing would the fault codes need clearing ??
    the RAC left them on
    Northampton
    Engine : A20DTH
    Mileage : 88000
    what were the codes that were read?
    what engine do you have?
    what is the mileage?
    What year is your car?
    The more information you can give us the more likely we will try and help, we cannot read your mind!
    May 2011
    washington
    car is a cdti 150 04 plate 136000 miles
    code says P0115 Engine Coolant Temperature Circuit Malfunction
    thanks
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Cumbernauld, Scotland
    Once a sensor has been replaced the EMS should realise the fault has been rectified
    However, it can remain logged and live for up to 10 engine starts
    It can help to take they key out, walk round the car, then restart
    I find this is usually enough time for the EMS to reset
    Another is to disconnect the MAF, start the engine, switch the engine off, reconnect the MAF, take the key out, lock the car, wait 10 minutes, and then restart
    May 2011
    washington
    cheers Guys for the great advice as always
    i will give it a try in the morning
    i love the car really just get peed when it is broken lol
  1. vectra c 1.9 cdti 150 wont rev past 2000
    By safayth1993 in forum Vectra C / Signum Troubleshooting
    Last Post: 4th January 2013, 20:08
  2. Wont rev past 2500, no power
    By silvershadow in forum Engine & Drivetrain
    Last Post: 7th March 2012, 11:16
  3. Vectr C wont rev past 2500
    By Rallyingden in forum Engine & Drivetrain
    Last Post: 13th March 2011, 12:59
  4. Wont go past 3000rpm
    By dannybutts in forum Vectra C / Signum Car Chat
    Last Post: 24th May 2010, 18:08
  5. 3.2 v6 wont go past 4k
    By crash112211 in forum Engine & Drivetrain
    Last Post: 18th January 2010, 13:31
