Results 1 to 10 of 11
Thread: P0110 Intake air temperature sensor
    Regular Member ScottyV6's Avatar
    Feb 2011
    Worcester
    Default P0110 Intake air temperature sensor
    The latest fault I am getting on my Z30DT is P0110. which shows as Intake air temperature sensor. Is this built into the MAF or separate part? Could somebody tell me where to find it please?
    Feb 2011
    Worcester
    Anybody?
    Regular Member Hue Jarse's Avatar
    May 2012
    Farnborough, Hampshire
    Engine : 1.8 VVT (Z18XER)
    Year : 09
    The IAT sensor is incorporated into the MAF. The IAT signal comes from the brown/black wire on the MAF on the Z30DT engine.
    (On the 1.8vvt it's the brown/green wire and I think it's blue/white on the Z19DTH.)
    Cumbernauld, Scotland
    Just make sure you order the correct MAF for this engine
    The lifespan of this sensor is about 12 years, but if you are using the car for lots of short journeys it can pretty much half that
    Equally, is this fault putting the EML and Safe Mode on?
    Feb 2011
    Worcester
    Cheers fellas, it's not going into limp mode, just the EML light! Going to clean sensor tomorrow, to see whether that helps over the weekend. Cars booked in next week at stealers to get the tie rods changed so if cleaning doesn't work, then will just order replacement MAF.
    I doubt it is the MAF sensor, as when you disconnect this engine goes straight into Safe Mode
    Sounds more like it is the sensor on the Inlet Manifold, try disconnenting that and compare
    Feb 2011
    Worcester
    So could the sensor on the inlet manifold also cause the p0110 intake air temperature fault to show? Thanks for your help m8
    It is possible, as the temperature will be calculated from the differential from a known temperature
    The MAF will be providing the incoming air temperature and the Inlet Manifold the temperature after the MAF and just before entering the Manifold
    The EMS will then work out the air flow, based on these two temperatures and the engine speed
    If one of these two temperatures is missing then the EMS will use the input from just one sensor
    If both sensors fail, then the engine will operate in Safe Mode
    Feb 2011
    Worcester
    Cheers mate! Took MAF and IATS of this morning, easy job on the z30dt. IATS was covered in sludge, so cleaned that off to find the resistor caked in hard carbon. Which soon broke off using some electrical contact spray cleaner. And lo and behold car now runs a lot better, just need to clear the code off now. Thanks again m8internet
    for future reference the IATS on the z30dt is just before the throttle body!
    Feb 2011
    Worcester
    Update! Just ordered a new MAF as car not running so good. occasional misfires since cleaning it. I will update once the part has arrived and fitted to see whether it cures my symptoms.
  1. Intake Air Temperature Sensor - Where is it?!
    By yates in forum Engine & Drivetrain
    Last Post: 10th December 2012, 19:17
  2. Temperature Sensor?
    By JaceyBoy in forum Engine & Drivetrain
    Last Post: 18th May 2012, 21:52
  3. intake air temperature sensor 1.9 16v CDTi
    By si_sri in forum Engine & Drivetrain
    Last Post: 26th April 2010, 13:27
  4. outside temperature sensor
    By billyyoung in forum Electrical & ICE (including SatNav)
    Last Post: 23rd March 2008, 17:23
  5. Outside Temperature Sensor U/s
    By turnerk in forum Electrical & ICE (including SatNav)
    Last Post: 17th July 2007, 22:05
https:www.vectra-c.comforumshowthread.php182570-P0110-Intake-air-temperature-sensor
vectra c intake air temperature sensor
vectra c air temp sensor
iat sensor vectra c
p0110 z19dth
vectra c 1.8 intake air temperature sensor
manifold heat sensor vectra
p0110 zafira
VAUXHALL P0110
Vauxhall vectra c air intake sensor
p0110 vauxhall
where is air inlet sensor on zafira
where is the temperature sensor on a vectra cVauxhall P0110(07)what causes vauxhall fault code po110iat sensor vectra c vvt z18xeriat sensor z18xer vvt enginewhere is the iat sensor z18xer vvt enginewhere is iat sensor on vauxhall insignia 1.8what is ait sensor vauxhall inaigniavectra b p0110vectra c 2003 air temperature sensor inlet manifold where is air intake temperature sensor on 2005 zafiravauxhall zafira Intake Air Temperature vauxhall zafira 2010 inlet temperature sensor
