Results 1 to 10 of 15
Thread: Trying to fix my leaky sump rim
    Nov 2012
    Norfolk
    Vehicle : BMW
    Trim : 320D
    Engine : .
    Default Trying to fix my leaky sump rim
    So after finally chiselling my sump plug out, I damaged the rim so now the new plug leaks oil.
    I've now taken the Vec off the road to drain the oil and try to fix it. (Currently driving an E36 compact... )
    Here's a couple of pics I took tonight:
    So tonight I took the vec off the road to drain the oil, il leave it a couple of days then try & seal it with something.
    I planned to drain the oil, let the surface dry out, clean it up & fix it with chemical metal, file it smooth & try again.
    BUT
    After looking at the surface, do we think a copper crush washer may do the job? I have taken out 7 days insurance on the BMW so I need to get this fixed ASAP.
    Cheers!
    Regular Member Beardy's Avatar
    Oct 2012
    Thetford
    Engine : 1.9 CDTI
    Mileage : 160500
    Tbh mate its worth a try with a washer/rubber ring to seal it temporarily but will need a new sump in the long run as will bo doubt fail with age.
    Regular Member Neve'o's Avatar
    Norfolk
    Vehicle : Vectra SRi 150 Hatch
    Mileage : 69'000
    If it was me I would use a fine metal file to get that mounting face nice and smooth, remove all the gashes, refit plug with new washer/sealing compound such as RTV. It doesn't look all that bad tbh, I've repaired worse!
    Feb 2012
    sheffield
    Vehicle : SIGNUM 1.9 CDTI ELITE
    Trim : ALL OPTIONS ELITE
    Engine : 1.9 CDTI 150
    Mileage : 140,000
    deffo file it down...just enought to take the rough off then get some fiber washers (2 of as thick as will go on) place copper wash on sump plug, then two fiber washers and tighten to the sump, warm the engine up and re tighten a little, that should cure it.......sometimes helps to soak the fiber washers in oil for a few hours before you fit.
    Feb 2012
    sheffield
    Mileage : 140,000
    chemi metal will not work! the idea behind the fiber washers is that they soak up the oil that seeps through the gap and they will only soak up what they can hold....they then block and seal, they were mainly used on old machinery with rough sealing face tolerances.
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Dowty washer - like this:
    and PTFE tape on the thread may just seal it...
    Filing the face will be OK if you can be sure to get the face flat. Very difficult with a hand file.
    Sep 2012
    expat Lancashire lad in the Midlands
    Engine : 3.2
    Dunno about the Vec but I had to replace the sump pan on my bora and it was pretty cheap.
    hull
    That doesn't look too bad, try the washer route if i were you.
    And what bladeage1 said chemical metal won't work, he's right cos i tried it on the wifes hyundai coupe, ended up putting new sump on it, surprisingly cheap at £40 from stealers.
    Nov 2012
    Norfolk
    Vehicle : BMW
    Trim : 320D
    Engine : .
    So I filed the surface down..
    crush washer was too small.. ******. Cut it, fitted it & bent it back together.
    The chip at the bottom is too big to draw out, so I had to try chemical metal putty. After a lot of thinking, I decided the best route was to seat the putty, screw the plug back in while soft so it moulds to the shape.
    This actually worked, but as I plan to change the sump anyway, I wanted to make it as leak proof as possible...
    Left it to set for an hour to set, put some oil in, seems dry, filled it up, ran the engine for 10 mins.. Still no sign of oil.
    We'll see how it goes!
    Regular Member Teapot's Avatar
    woodbridge, suffolk
    278 Post(s)
    Trim : Design+
    Mileage : 101000
    I know its a bit late for you now, but when mine got stuck I used a dremel with cutting disc to carefully cut off two sides of the plug flange, leaving flats that an open ended spanner will fit on and . Its a bit more accurate than a chisel, as long as you have a steady hand.
    And yes, i did break about 6 dremel cutting discs in the process. If anyone can do it with less than 3 discs, I take my hat off to them
  1. Dti sump
    By dwaine123 in forum Engine & Drivetrain
    Last Post: 13th January 2013, 20:32
  2. leaky leaky leaky :(
    By bappy in forum Engine & Drivetrain
    Last Post: 12th August 2012, 13:31
  3. Leaky exhaust joint
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 10th February 2009, 21:43
  4. leaky oil cap
    By peadar in forum Engine & Drivetrain
    Last Post: 13th October 2008, 08:02
  5. Leaky boot on the vectra
    By lee_eardley in forum Vectra C / Signum Car Chat
    Last Post: 29th May 2007, 22:01
