Does the Vectra VXR have a coolant draining plug?
If so, where would it be located?
If not, what's the easiest way to drain coolant?
is there a haynes manual for the facelift vectra 2.8 or vxr?
On the bottom of the rad on drivers side is a small tap will more than likely need pair of pliers to turn it
and it's best to use a hose pipe on the end or you'll get coolant everywhere
Cheers.
Also all the how to's I've seen about changing the oil on the vectra vxr have broken image links. Do you know of one that doesn't?
