Thread: Are there any gas experts here? (butane/propane)
    Nov 2010
    Maidstone
    Default Are there any gas experts here? (butane/propane)
    To cut a long story short, im looking to take the littlun camping when the weather picks up and going down the route of getting whats needed. Im in the motion of dealing with the cooking side of things and popped into a local costco to see what they had on offer. Now its a bit bigger than you would normally use for a portable cooker but the quality is excellent for £90, now the only problem is that i have a 15k butane tank at home but this states it uses propane. What are the differences and could butane be used or will it destroy anything? Any help much appreciated.
    http://www.amazon.co.uk/Nexgrill-Por.../dp/B003HU9GGO
    Dec 2010
    London
    5 Post(s)
    Vehicle : Hyundai Ioniq Hybrid
    Trim : Premium SE
    Engine : 1.6 with 32KW motor
    Make sure you cook outside of tent not inside even if its raining.
    Nov 2010
    Maidstone
    Is this true for both butane and propane? Is this because this type of grill will crate more heat than a normal camping type?
    Regular Member Happy Girl's Avatar
    Never enough Costa!
    Vehicle : Coupe
    Trim : SE
    Engine : 2.L
    Year : 55
    Propane burns at a higher tempreture than butane.............. You could just buy a different regulator and use the butane instead.
    Nov 2010
    Maidstone
    Thats what im wondering, is if it will be ok to butane on this machine, will it damage the burners using a different gas than suggested?
    Regular Member veclee's Avatar
    Nov 2012
    skegness
    Vehicle : vectra c
    Trim : club
    Engine : 1800
    Mileage : 63000
    And propane operates at much lower temperature basically it don't freeze up as easy as butane dos
    Never enough Costa!
    Vehicle : Coupe
    Trim : SE
    Engine : 2.L
    Year : 55
    I am not to sure on that sorry. You might be able to exchange your 15kg butane for a 13kg propane bottle. You would have to pay for the cost of an exchange even if there is still gas left in your bottle.
    Nov 2010
    Maidstone
    Doing a bit of reasearch it turns out using butane on a propane cooker could damage the jets/burners, not sure if its worth the risk.
    Norwich
    Trim : SXi
    Engine : 2.2
    It will work but you will end up burning it out. Stick with what is recommended would be my advice
  1. a bit of help from the experts:)
    By macs_silviu in forum Bodywork & Interior
    Last Post: 9th July 2012, 22:41
  2. Looking for experts
    By Rebellion8878 in forum South Central (ARO - Brady )
    Last Post: 4th March 2011, 12:47
  3. Remap/ecu experts
    By Wolflinn in forum Petrol Engine related
    Last Post: 14th September 2010, 12:21
  4. any clutch experts on ere that can help me?
    By vectra08101981 in forum Introduce yourself.
    Last Post: 3rd June 2010, 12:51
  5. any clutch experts ere?
    By vectra08101981 in forum Engine & Drivetrain
    Last Post: 3rd June 2010, 11:18
