Thread: noise fron nsf wheel
    Oct 2012
    Ashford, Middlesex
    Default noise fron nsf wheel
    hey guys
    did my dmf a couple of weeks ago following the how 2 guide. i made a couple of **** ups putting her back together though :-(. 1st when i renewed the crank oil seal i didnt use any sealer on the bottom bit where it joins the sump 2nd i think i over torqed the hub nut resulting in a noise when i turn right and the weight is transferred to that corner. i got a different bearing but its still making the noise so is it possible i've damaged the shaft aswell ?? honestly i am well and truely p#ssed off with myself but these thing happen
    Chelmsford
    I'd have suggested the bearing to be at fault, I had exactly the same issues when mine was worn. NSF was grinding when turning right and pressure was put on it.
    Doubt you've damaged the shaft to be honest, would have expected a knackered shaft to produce a constant noise, rather than just on turns.
    Oct 2012
    Ashford, Middlesex
    ok cheers for that mate, just really anoying :-(
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    Check you have not just squeezed the dust cover for the brake disk against the disk, its quite a common thing to happen.
    Jan 2013
    Engine : 2.0T
    I'm getting this exact thing as well, it's done it since about 15 minutes after I bought the car (grrrr), was hoping it was just some debris stuck in the pad since the car had been sitting around for a while, but it's not going away. I'm planning to have the NSF wheel off and have a good look around when I get a chance (hopefully Sunday). Any tips on what I should be looking for?
    If it's a bearing, is this a DIYable job for someone moderately handy, or is it going to need a trip to the Garage?
    Regular Member shb1988's Avatar
    Oct 2010
    sittingbourne
    3 Thread(s)
    Vehicle : vectra
    Trim : gsi
    Engine : 3.2 v6
    Mileage : 69,000
    I have recently replaced wheel bearing and drive shaft on the Ns of the car, bearing was droning and inner cv was clunking when on rough roads, so driveshafts can be to blame but cancel it out by holding it and pulling towards the wheel and back towards the gearbox, if it makes a noise it would be similar to your noise
    Full Member Johnsdutton's Avatar
    East Kilbride
    Engine : 3.2 v6
    Mileage : 140,000
    As Das said before you do anything check the dust cover. I had same problem and that sorted it.
    3.2 v6 Signum and loving it 😁
    Oct 2012
    Ashford, Middlesex
    cheers guys, im gonna have a goid look tomorrow, wheel bearing was gone but manged to get a whole hub and bearing off another 05 plate car to try it but still the same, gonna try the driveshaft tomorrow to but failing that gonna get a new bearing, there an easy fit once whole hub is out so not to bad
    Oct 2012
    Ashford, Middlesex
    brand new wheel bearing fitted and still the same :-(
    Oct 2012
    Ashford, Middlesex
    different drive shaft and still the same........stumped
  1. ta technix fron height adjustment
    By 6009tristanb in forum Suspension, Wheels & Brakes
    Last Post: 7th July 2012, 19:52
  2. Anyone fron Northampton or close by
    By Angel1368 in forum The 'Off Topic' room
    Last Post: 18th June 2012, 20:50
  3. Hi fron rasher
    By Rasher in forum Introduce yourself.
    Last Post: 21st April 2012, 19:04
  4. Wheel Alignent or New Tyres? Noise Noise Noise
    By lostdog in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2011, 13:29
  5. any 1 fron colchester/ipswich area?
    By Craig1985 in forum General Chat
    Last Post: 25th February 2008, 22:06
