Thread: what should i be changing
    Oct 2010
    manchester
    Vehicle : vectra sri
    Engine : 1.8 vvti
    Mileage : 77000
    Default what should i be changing
    i have a 2006 1.8 sri nav thats just hit 75k going to give it a full service with extras but what extras ?? was thinking the following am i right
    timing belt
    solenoids
    new springs all round
    also what are the best spark plugs to fit was going to use ngk iridium plugs
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    Add brake fluid and a coolant change to that list. I have iridiums in my 1.8, are the worth the extra, dunno, but they were not that more expensive. Pollen filter too, get a carbon impregnated one, much better than standard.
    Regular Member JagRigger's Avatar
    Norfolk
    6 Post(s)
    Engine : 1.8 VVT
    Mileage : ... 256K!
    I'd only do springs and solenoids if they need it. If it's a VVT, the belt is actually 100K but that's your choice.
    All fluids change / check is good advice I'd say - including having the air con serviced
    Oct 2010
    manchester
    Engine : 1.8 vvti
    Mileage : 77000
    i think its a vvt but have no idea how to check lol
    West
    Don't forget the water pump
    I have to agree, based on projection it will reach 90K miles at next service
    At that service I would do the Cambelt and Water Pump
    It would also be helpful to know what was done on the previous service, when these were and at what mileage, to work out what is due to be replaced now
    For the current service I would consider at least the oil, oil filter, pollen filter, and fuel filter
    If the last service did not include an air filter then add that
    If the Brake Fluid was not replaced since 2011, then add that too
    The Spark Plugs can last up to four services / four years, so these should have been replaced in 2010
    For the other components the service schedule should highlight if any steering and/or suspension components need replacing
    If they do, then replace both sides, not just the faulty one
    Regular Member puppet's Avatar
    East Ayrshire
    10 Post(s)
    Vehicle : Insignia 1.8 SRi
    Trim : VX Line Red
    Engine : 1.8VVT
    Year : 2011
    Don't forget that the water pump isn't driven off of the timing belt on the VVT, it's off of the aux belt, so not essential to change you could argue. That said though, I have just had a timing belt kit fitted to my own VVT at 58k, and opted to have the pump changed at the same time as the garage was in about that area anyway.
  1. Changing 215/50 to 225/45 on 17s ??
    By jonesy_ni in forum Handling & Braking
    Last Post: 3rd September 2008, 21:06
  2. Help with changing my car please
    By deanos in forum Vectra C / Signum Car Chat
    Last Post: 4th July 2007, 20:41
  3. why am I changing my car ?
    By rob 2.2dti in forum General Chat
    Last Post: 30th May 2007, 23:56
  4. Changing from 17s to 19s
    By welshy in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2007, 22:41
  5. changing again ?
    By david-bell in forum Vectra C / Signum Car Chat
    Last Post: 28th March 2006, 20:50
