Thread: 1.8 vvt a good engine?
    Jul 2010
    cambridge
    Default 1.8 vvt a good engine?
    As title says.
    Looking to replace the wife's zafira 1.9 cdti '57 as I am fed up with the constant problems/ breakdowns associated with it e.g. egr, dpf, dmf etc.... Never seen the spanner/ eml light so many times as I have on this thing.
    I have the 2.2i vectra which runs flawlessly so thinking another vectra (petrol) replacement for the zafira is the best option.
    Is the 1.8i vvt any good? What are the commons faults, if any, other than the water pump needing changing at 70K.
    Regards
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    Yes its a very good engine. Only known fault is the vvt solenoid, the filters clog and cause a rattle on start up but you can remove them or replace them unit relatively cheaply. Water pump does not require changing at a set interval, and as it is run from the aux belt and not the timing belt does not even need done whit the timing belt. Belt is 100k or 10 years but 80k is a more safe recommendation. Thermostat the only other real fault, but thats the same over the whole VX range tbh.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 167340
    Regular Member Niall83's Avatar
    Nov 2009
    Belfast
    Trim : Exclusive
    Engine : 18VVT Z18XER
    Mileage : 130k
    The guys above have cover the faults I know off. I love min, great engine.
    Regular Member Envy's Avatar
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    Im a 100 odd miles from 100k on a 06 plate. Only real engines problems have been thermostat and coilpack.
    Most reliable car i have owned in 25 years of motoring.
    Will be a crying shame when i have to sell it.
    Nov 2011
    Oxford
    Vehicle : Sri xp1
    Engine : 1.8
    Mines playing up on way home tonight joining motorway a loud bang then loss of power engine light is on and missing aswell not at all happy now
    Regular Member JagRigger's Avatar
    Norfolk
    15 Post(s)
    Engine : 1.8 VVT ( No2 ! )
    Mileage : 310 k !
    105 K on mine. Averages around 40mpg if not driven hard. Gutless low down, but ok if you get above 3500 rpm ( redlines @ 6500 )
    Have changed the coilpack and solenoids in the 80K I've had it
    Regular Member bigstu31's Avatar
    May 2012
    Southampton ish
    Vehicle : vectra
    Trim : Sri
    Engine : 1.8 vvti
    Mileage : 64000
    Good engine and pretty quick considering small engine/ big car. Love mine can be bit juicy on fuel at times also changed coil pack at 52000 otherwise not one prob
    Nov 2011
    Oxford
    Vehicle : Sri xp1
    Engine : 1.8
    change coil pack yesterday erased fault codes and happy times again running like a dream
    Regular Member Exclusive BV's Avatar
    West Midlands
    Quote Originally Posted by Chewy72 View Post
    glad you got that sorted mate, did'nt realise the coil packs went like that, thought they just did a bit of juddering
  1. 3.0v6 diesel a good engine?
    By Steven in forum Vectra C / Signum Car Chat
    Last Post: 7th January 2013, 00:27
  2. Were you ever good at imitating a particular engine...?
    By Telly Addict in forum The 'Off Topic' room
    Last Post: 27th May 2010, 19:04
  3. 2.2dti engine, any good?
    By STAV in forum Vectra C / Signum Car Chat
    Last Post: 28th January 2008, 14:29
