Hi Guys,
Manual 3.0 cdti. Car drives normally unless you go above 2800-3000 revs then the spanner comes on and lovely limp mode..
Stop turn car of for a minute turn back on and away you go normally again untill the next time you go above 3000 revs or above say 95 in 6th gear. I had my mates diagnostic systen connected up and it gives P0105 Boost pressure sensor High input circuit error. I believe this is the boost sensor or map sensor (same thing I Believe). So is this right and If so Where Is it on the engine as I cant find it (picture would be good)
Any info thanks....
