Results 1 to 2 of 2
Thread: Inner Tie Rod Removal
    Nov 2012
    Derby
    Vehicle : Vectra 1.9 CDTI 120
    Trim : Energy
    Engine : 1.9 8v 120 BHP
    Mileage : 170, 000
    Default Inner Tie Rod Removal
    I'm going to have a go at changing my inner tie rods and although I have no problem with the outer tie rods I'm a bit restricted for access for the inners what with my belly and getting under the car. I have the special tie rod tool along with everything else...... My main question is, is it necessary to remove the inner retaining clip on the Gaiter ?? can I not just remove the outer clip and push the gaiter back to gain access ?
    Scotland
    You will need to remove both retaining clips. The gaters will need swapped over to the new tie rods. Unclip both ends and pull the gater towards you giving access to remove the tie rod.
  1. 3.0 Dpf removal?
    By Steven in forum Y & Z30DT Specific
    Last Post: 22nd June 2013, 13:15
  2. Egr removal
    By Dougb in forum Engine & Drivetrain
    Last Post: 16th May 2010, 19:09
  3. Nut Cap Removal
    By ChrisBilly in forum Vectra C / Signum Car Chat
    Last Post: 16th March 2010, 17:01
  4. DPF removal
    By sthomson1 in forum Engine & Drivetrain
    Last Post: 16th March 2009, 17:01
  5. pre-cat removal
    By linley85 in forum Petrol Engine related
    Last Post: 16th November 2008, 18:51
vectra c inner tie rod removal
vectra c inner tie rod tool
vectra c inner tie rod size
vectra c tie rod symptoms
inner tie rod vectra c
How to remove vectra c inner tie rod
vectra c inner tie rod gaiter clip
vectra c tie rod failure
vectra c tie rod nut size
vectra inner tie rod change
vectra c inner tie rod replacement
vectra c tie rod replace
what size nut om a vauxhall vectra innmer tie rod
2008 vectra inner tie rod
vectra c tie rod size
https:www.vectra-c.comforumshowthread.php182428-Inner-Tie-Rod-Removal
vectra tie rod end socket size
vectra c drivers side inner tie rod removal
vectra c tie rod what size tool
vivaro inner track rod replace
