Thread: Vectra AF23 Oil ?
    Jan 2012
    Telford
    Default Vectra AF23 Oil ?
    Hiya guys, was looking to do a Gearbox oil change, looked all over the internet, looked in haynes manuals and contacted Vauxhall, Vauxhall have said they do not know what sort it is they can only locate it by part number. Any ideas guys?
    Jun 2011
    brum
    All i did was google "Vectra AF23 Oil". The 4th result looked the most valid so clicked on it and got to this: http://opeltis.spaghetticoder.org/doc/en/23857 . which reveals a part number you can then take to a stealers or google for an online seller (PN: 93160393) . and after 2 minutes googling the PN and cat no, i quickly realised that gearbox oil isn't as generic as engine oil so i was beating up the wrong track trying to find your standard oil rating, then realised that gearbox oil has a separate rating system for oil, and the one you want is "ATF 3309" (ATF = Auto Trans Fluid), which you can get from mobil.
    Gotta love google sometimes
    Regular Member fikse's Avatar
    Apr 2009
    Bergen, Norway
    AFAIK all Aisin Warner autoboxes is to use a JWS3309 spec'd oil. Several brands does have this oil, so it should be easy to get. Will highly recommend to get a full flush, and not only a oil change. Fully syntetic is preferred, as the Aisins runs warm. Valvoline has come up with a JWS3309 oil, fully synth, that is specifically designed for used gearboxes. Might be worth looking at. If you're into getting the cheapest, your dealer might be OK, or maybe better/cheaper, a Toyota dealer.
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Post in the opieoils section and they will help you. Really sound guys
  1. Vectra AF23 Gearbox problems
    By PJL in forum Engine & Drivetrain
    Last Post: 19th July 2010, 07:22
  2. af23 auto gearbox problems
    By andyadams in forum Vectra C / Signum Troubleshooting
    Last Post: 25th May 2010, 21:24
  3. How do i Know if i have AF23 0R AF33?
    By mikaj in forum Engine & Drivetrain
    Last Post: 2nd August 2009, 14:11
  4. which oil for autobox AF23. veccy2.2 auto
    By pinnacare in forum Vectra C / Signum Car Chat
    Last Post: 24th October 2008, 14:00
  5. af23 gearbox problem
    By azn_007 in forum Engine & Drivetrain
    Last Post: 16th January 2008, 00:06
https:www.vectra-c.comforumshowthread.php182426-Vectra-AF23-Oil
af23 gearbox
