Results 1 to 3 of 3
Thread: Pressure washer problems
    Nov 2010
    Maidstone
    Default Pressure washer problems
    I have been given a Karcher 650M non runner to see if theres anything i can do with it. As im a bit of a novice when it comes to pressure washers i need a little help. Ive established that theres power getting into the unit and when the button on the front is pressed the light comes on but nothing at all is heard, not even pump trying to move, has anyone got any ideas?
    Jun 2012
    North Shields
    hi mate. sounds like a one i fixed for a mate of mine last year. some washers have a pressure switch inside . if it doesnt detect water pressure from the hose it stops the motor working ( safety feature ). dont know how confident you are at mucking about with it but the pressure swich can be bypassed and the power
    taken straight to motor but you will lose the safety feature. hth.
    cheers john
    Nov 2010
    Maidstone
    Right the pressure switch was jammed tight in there with limescale so have removed it. I located micro switch, turned on mains, depressed microswitch and the motor fired into action so i know that works fine. Ive cleaned all mating surfaces in the pressure switch recess with wire wool, bit of white grease and she moved freely. Put all back together, plumbed in, she fired up, pressurised and motor shut off as it should. Then pressed the lance handle and pressurised water came out for split second then dropped off and the motor just keeps running with no pressure, any ideas?
  1. New Pressure Washer
    By hodge725 in forum Detailing and Car Care Discussion
    Last Post: 31st October 2012, 13:12
  2. which pressure washer to buy?
    By MURDO in forum General Chat
    Last Post: 29th March 2012, 21:47
  3. Pressure Washer
    By deanos in forum General items for sale
    Last Post: 26th January 2008, 22:43
  4. Pressure washer
    By BigP in forum Detailing and Car Care Discussion
    Last Post: 25th May 2007, 21:48
