Hi all
a little bit of a strange question but does anyone know if a facelift Sri steering wheel will fit on a 2009my Zafira Elite?
looking forward to you help guys....
cheers
Phill
Hi all
cheers
Phill
the steering wheel will fit on but i think you would have to swap the all the leads over inside the wheel
Yeah as far as I'm aware you would need to swap the electrics from your current steering wheel
After speaking to a Vauxhall technician i know it would appear that the wheel would fit however the multiplug for the airbags are different between zafira's and vectra'c and wont fit through the hole in the steering wheel...
so looks like i'm still on the hunt for a Zafira B steering wheel...
They are the same steering wheels fella so the plug does go thru the wheel as I've fitted a Astra Vxr wheel to my vec in the past so he's talking rubbish fella
chrisvectra thanks for that, as you can probably tell i'm not that technically minded. Next will be the fun of trying to change it i suppose...
Park the car so that the steering wheel is correctly centred, turn off the ignition and remove the key.
Wait for 10 minutes, some will say longer, so give it half an hour and then disconnect the +ve from the battery. (The waiting time allows the computer modules in the car to shut down properly).
After that it's airbag removal time (there are how2's on the forum for that, so just search). Then you need to undo the steering wheel audio controls (T20 screwdriver with a single screw for each from behind). After that the rest will make itself clear, 3 more screws (Torx) let you remove the steering wheel button/scroller electrics. And after that, another Torx to remove and replace the steering wheel.
I don't think I missed anything but I'm sure that if I did, someone will jump in .
HTH
Woody
This all assumes that your existing airbag mates with the new wheel, or, that the new airbag mates with the wheel and car electrics
