Thread: Should i replace water pump during cam belt change ?
    Regular Member Allvec150's Avatar
    Mar 2012
    Salsburgh
    Trim : SRI
    Mileage : 89k
    Default Should i replace water pump during cam belt change ?
    Hi all, im going to replace my timing belt and pulleys and was wondering if it is worth my while replacing the water pump at the same time. its a vec 150 cdti with 85k on it and sounds ok when running so i was going to leave it but i thought i would ask what others think and if the pumps are common ish fault or not?
    Any thoughts would be appreciated, thanks
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    You'd be stupid if you didnt, have a search for cambelt failures on this site.
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Absolutly yes.
    Its the pumps and pulleys that fail - not the belts.
    Genuine only for the pump and belt kit (includes tensioner, pulley and bolts)..
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 167340
    yes the waterpump is a must
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    Quote Originally Posted by AntSSSS View Post
    Absolutly yes.
    North West - Assistant RO Woody's Avatar
    May 2012
    North West (Warrington)
    240 Post(s)
    Vehicle : Vectra C 3.2 Elite Estate Auto Facelifted
    Trim : Elite with loads of "Extras"
    Engine : 3.2 Z32SE
    Mileage : 94,000
    100% YES ! Trying to cut the cost on such a low priced part while you are replacing the rest of the kit would be absolutely mindless. The waterpump does so much work for what it is, then it is almost certainly due for a change when the other parts are done.
    Remembering that if you don't, a pump failure and seizing up will cause an almost instantaneous belt failure when it happens.
    Been there in days of old, and got that Tee Shirt already fella, you will NEVER feel sicker than if that happens to you after you were advised to change it and decided not to
    Regular Member SEANYboi's Avatar
    Dec 2012
    Bourne end,high Wycombe
    5 Post(s)
    Vehicle : Vauxhall vectra
    Trim : Sti nav
    Engine : Cdti 150
    Year : 55
    Mileage : 96000
    Regular Member stevoxsi's Avatar
    Sep 2012
    Coleraine, Norn Iron.
    Vehicle : Insignia
    Trim : Sri Vx-line
    Engine : 2.0 Cdti 160
    Year : 2011
    Without a shadow of doubt. Mine seized at 89k, no warning. I was lucky the belt didn't break.
    Regular Member Morephun's Avatar
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    Quote Originally Posted by stevoxsi View Post
    don't say that m8....ive had every problem relating to the 150cdti just the dmf left I thought....oh well another sleepless night eek...
    Sep 2012
    Vehicle : Insignia
    Trim : Sri Vx-line
    Year : 2011
    Quote Originally Posted by Morephun View Post
    Get it changed sooner, rather than too later!
  1. My Car was in Garage for Timing Belt and Water Pump Change
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2013, 22:31
  2. £280 for Cam Belt and Water Pump Change on a CDTI 150??
    By Henry42 in forum Vectra C / Signum Car Chat
    Last Post: 3rd March 2013, 20:51
  3. Did cam belt and water pump change
    By dontsnatch in forum Vectra C / Signum Car Chat
    Last Post: 24th December 2012, 09:57
  4. Cam Belt & Water Pump change...
    By si_sri in forum Engine & Drivetrain
    Last Post: 27th June 2010, 21:48
