Results 1 to 10 of 17
Thread: low power and rubbish mpg on vec cdti 120 aaaagh!!!!!
    aberdeen
    Default low power and rubbish mpg on vec cdti 120 aaaagh!!!!!
    My vecy is now about 29 mpg round town. Used to be 34mpg minimum even with hard run. Low power. Turbo seems kick in 2500 ish. Shouldnt it be lot lower.dont here it dump /wind up.Mpg is garbage across range. Done usual. Cleaned egr . Boost sensor. Changd vacuum pipes at front. New glow plugs. Are there any other vac pipes to replace or could the egr if knacked cause this. Brakes etc not sticky so nothing to hold car back n tyres at correct pressure.lack of power from somewhere.used to pull well and mpg used be good too. Pleeeease help. Pic be good if any.thanks
    Nov 2012
    Derby
    Vehicle : Vectra 1.9 CDTI 120
    Trim : Energy
    Engine : 1.9 8v 120 BHP
    Mileage : 170, 000
    Notts
    did it used to have more power before? before the mpg drop?
    My 120 isn't exactly a powerhouse, but in the turbo range it moves, but as with the 120, the turbo just throws power at you when it kicks in. Has it had an oil change recently?
    aberdeen
    Carling and nucleo. Thanks for your replies. I will try the boost valve. Even at low revs with very light foot the mpg on instant display is ridiculous low. Way down at low teens with ****** all power even before turbo kicks. Just generally very sluggish through full range with crap mpg. Im trying all the obvious and cheaper options before i go further.had the air box apart and is pulling plenty air through when put hand over inlet.its def got something that has failed or changed as it used be a cracker for fuel economy and pull well. Something both related to fuel and power appears go d li med to same part /parts.
    Jan 2012
    Gloucestershire
    Before forking out on anything, I would unplug the EGR and see what it feels like. If the EGR sticks open you'll have all sorts of problems.
    If this doesn't help, blank the EGR entirely (not a Fiat gasket with a hole in, entirely blank it with a home-made plate - you'll find plenty of people who have done this on this forum). This will completely eliminate any problems the EGR could be causing - ignore the spanner light for now.
    I appreciate you've already cleaned it, but if the EGR is sticking even a bit, the exhaust gas will be recirculating constantly and would cause poor performance and MPG.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    As above, unplug EGR and test
    Also... oil, oil filter, fuel filter, air filter changed (basic service). Clean the boost sensor and EGR, and check vac pipes for splitting.
    Made the world of difference on my Vectra 120
    Jan 2012
    Gloucestershire
    Sorry, just to confirm, I meant unplug the EGR and drive around for a bit, not just see what the EGR feels like...! Will take you 1 minute to try, and £0.
    Jan 2012
    Gloucestershire
    And as Tony said, a basic service is a good plan as a next step. I replaced my fuel filter, which was unusually dirty last service (not sure why) and my consumption went from 42 to 48mpg. Also noticed that the design of the fuel filter had changed. The old one was a plain cylindrical paper filter, whereas the new one was corrugated, so much more surface area.
    aberdeen
    Guys thanks so far. Going to have a tinker tommorow and will get back with feedback.These issues appear so popular.just a pity our vauxhall parents couldnt have sorted these issues out years back and we could all be enjoying the forum instead getting hacked of with egr etc.appreciate your comments so far
    Jan 2012
    Gloucestershire
    Yes, but to be fair, not just Vauxhall. EGRs, Swirl flaps, DPFs, DMFs, numerous additional sensors - mostly trying to either reduce emissions or improve driving experience are on most modern vehicles and cause problems on most too. Even so, the 1.9cdti is a bit of a dog on reliability - performs well when its working!
  1. 120 CDTI low on power
    By Boris in forum Engine & Drivetrain
    Last Post: 27th May 2012, 00:04
  2. little power 150 cdti
    By smokydiesel in forum Engine & Drivetrain
    Last Post: 26th May 2010, 19:13
  3. no power cdti 150
    By paul wingnut in forum Engine & Drivetrain
    Last Post: 16th April 2010, 22:21
  4. 150 Cdti down on power??
    By shrekster in forum Engine & Drivetrain
    Last Post: 7th December 2008, 00:19
  5. Aaaagh, never going to be ready!!
    By AndrewTi in forum Vectra C / Signum Car Chat
    Last Post: 31st August 2007, 17:53
