Results 1 to 10 of 27
Thread: Time for a bigger compressor again
    South Central England
    18 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Default Time for a bigger compressor again
    Having spent time with Teapot and having continued to tweek, I now have a map that spools my hybrid to full pressure by about 2250rpm in fourth without the methanol now. So much more is available that I have had to limit torque in the map because it now slips the clutch around 2000-2500rpm without the methanol too.
    So as I am having to hold it back, I might as well go to a bigger compressor again and get even more top end.
    I've attached a graph for the boost pressure holding nice and steady, I didn't go full throttle until near 3000rpm as you can see so I could test of over boost spikes and it played very nicely
    peak was about 29psi, dropping back to sustain 26/27psi, all that is needed for 240+bhp
    Regular Member mrk's Avatar
    Vehicle : vectra hatchback
    Trim : improving
    Engine : 1.9cdti mas remap
    Year : 06
    you just love stripping turbos dont you? wish i had your patience and ability to tinker.keep up the good work m8
    Wirral
    10 Post(s)
    Engine : 1.9CDTi
    Mileage : Lots
    I bet you're really chuffed with that! I'll stick mine on a rolling road next week.
    morecambe
    54 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    looks mint that mate well done paul
    Regular Member STICKY3.2's Avatar
    Jul 2010
    Hertfordshire
    Does it go well?
    Regular Member Teapot's Avatar
    woodbridge, suffolk
    278 Post(s)
    Trim : Design+
    Engine : 1.9 CDTI 150
    Mileage : 101000
    Quote Originally Posted by STICKY3.2 View Post
    Does it go well?
    To my bum it felt exceedingly fast, but then I've not been in many quick cars lately ;-)
    Two minds on the job for a day seems to give good results, he just needs to sort out that clutch now!
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Quote Originally Posted by littleteapot View Post
    Teapottune strikes again - nice one @littleteapot Paul...
    How did you get on with the PCR values - anything changed from the map we did?
    18 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    It is much better low down, the methanol is not needed at the moment as I say. I have continued to adjust the torque request and VNT duty along with injection timming to produce the produce I have now. It is a great shame that the clutch is holding me down to about 370lbft at the road wheel but I can still progress by mapping in the MAF when it turns up and then fitting a higher flow unit to raise the boost to 29psi and push up the top end before fitting the uprated injectors.
    Middlesex
    Trim : SRI
    Mileage : 100k
    Quote Originally Posted by nutron View Post
    Do you get a boost spike Karl when you apply WOT from a low rev range to red line?
    I know Paul did a lot of work on the PCRguv values for mine to hold the boost - and it holds really well now (I am standard turbo however)...
    woodbridge, suffolk
    278 Post(s)
    Trim : Design+
    Mileage : 101000
    Quote Originally Posted by AntSSSS View Post
    we didn't make any more changes to the pcr governor, just the vnt duty cycle maps. there were some spikes but Karl managed to stop these by adjusting the vnt duty. didn't try any full throttle from very low revs as thats not something that happens in normal driving. its still on my to-do list though!
    The main thing in this case was to get a high enough iq to spin up the modified turbo at low revs. we ended up with a peak IQ of 120mm3 per stroke after finding the last limiter which was holding it back to 100mm3. Now there's no need for methanol as the diesel alone provides enough fuel to get good spoolup
  1. Bigger battery?
    By toaffer in forum Electrical & ICE (including SatNav)
    Last Post: 7th October 2012, 21:00
  2. bigger turbo
    By chikenbud in forum Vectra C / Signum Car Chat
    Last Post: 6th March 2009, 19:57
  3. bigger alloys
    By leeandjude in forum Vectra C / Signum Car Chat
    Last Post: 17th September 2007, 19:34
  4. Bigger calipers???
    By Auto-Brite in forum Handling & Braking
    Last Post: 28th August 2007, 22:27
