Results 1 to 10 of 15
Thread: Instrument cluster electrical problem - Please help
    Regular Member Mark's Avatar
    Daventry
    Default Instrument cluster electrical problem - Please help
    Started my Signum this morning and all the electrices within the instruments cluster were not working, no rev counter/ speedo/ backlight/ warning lights etc
    Car started, lights/ radio/ Nav etc all working but nothing within the instrment cluster.
    Local Vaux dealer told AA man to disconnect battery and leave for 5 mins to re boot the computer. This seemd to have workd but worried all the same.
    Anyone else had the same? Should I book this in as car under Vaux warrenty
    Thx
    Administrator plasma's Avatar
    On the Forum
    399 Post(s)
    Engine : 150
    Mileage : 74000
    hate to say this, same thing happens on my mate Vx Combi, all instruments go dead and he has to whack the dash lol to get it started. Vx put it down to a bad connector for the panel.
    Nicking Ya Dinner.
    You have plenty of time on warrenty Mark, see if it does it again, if you mtake it in right now they will say no fault found and charge you £50.
    it will have registered a fault, so just take it in.. the next time just see if it works if you turn it off and then on again..
    Nicking Ya Dinner.
    Limited number of starts remember Mark, plus it may have cleared when he took the battery lead off.
    it will have cleared yep.....
    He'll have to wait till it happens again....
    Nicking Ya Dinner.
    Tsks!!!
    SCOTLAND
    I had this on my old corsa c. Fixed 9 times then it went again and i 'got a deal' from vaux to replace the car hence i'm in my veccie On the corsa you couldntstart the car either when this happened
    The Fault was put down to the cable coming loose at back of instrument panel. Pushing the instrumnets usually brings this back as a temp measure or did on corsa. Other faults could be the body control module.
    Hertfordshire
    Didn't some of the earlier Vecs have a problem with a loose/bad connection somewhere behind the battery, ABS connector or something ?
    T'was the ABS plug....
  1. instrument cluster
    By waky in forum Electrical & ICE (including SatNav)
    Last Post: 3rd December 2011, 00:31
  2. instrument cluster
    By veccyv6 in forum Vectra C / Signum Car Chat
    Last Post: 25th August 2011, 19:03
  3. Instrument cluster part no please
    By bale541 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd May 2011, 16:45
  4. Instrument cluster
    By Daywalker in forum Electrical & ICE (including SatNav)
    Last Post: 8th November 2008, 18:43
  5. Instrument cluster
    Last Post: 12th October 2008, 20:02
