Thread: rear parking swap over?
    Regular Member Del101's Avatar
    Dec 2012
    York
    Default rear parking swap over?
    Not sure how to go about this other than to ask you guys, I want vauxhall parking pilot for my 2006 vectra sri cdti and I have been offered a VXR rear bumper with the rear skirt and built in parking? how ever my question is would you parking transfer straight over to my vectra? and the bumper I have been offered is in red, will the outside senorses repaint into silver ok?
    North West - Assistant RO Woody's Avatar
    May 2012
    North West (Warrington)
    234 Post(s)
    Vehicle : Vectra C 3.2 Elite Estate Auto Facelifted
    Trim : Elite with loads of "Extras"
    Engine : 3.2 Z32SE
    Mileage : 94,000
    You may be able to use the parking sensors in your Sri, I would imagine the chance of them being the same part is quite likely but you should really check part numbers to make sure. The ones you need for your car are 9198958 from 2006 onwards AFAIK.
    However, that is just the beginning, you will also need the rest of all the parts needed if you are planning on retrofitting the Vx system. You will need the loom, rear speaker unit and the ParkPilot Module itself, together with the bumper mount fittings if you are going to make use of it. If you intend to fit front sensors too, then you will need the ParkPilot dashboard switch, front loom another 4 sensors and another set of mounting fittings.
    This kit will also need to be programmed into your car after you have fitted it.
    HTH
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Trim : Irmscher Elite
    Engine : 3.0 CDTI
    the looms are your main deciding factor IMHO. Getting to them before the scrappers cut the plugs off to sell the bumper it the key.
    Dec 2012
    York
    ok thanks for the advice
  1. Signum rear seat swap?
    By Paul_O in forum Bodywork & Interior
    Last Post: 23rd September 2010, 22:21
  2. Rear Lenses swap!!!! easy or not???
    By bigb1983 in forum Bodywork & Interior
    Last Post: 11th June 2009, 16:11
  3. Rear light swap
    By SteveH in forum Styling
    Last Post: 18th April 2008, 23:19
  4. rear light swap
    By SteveH in forum Vectra C / Signum Car Chat
    Last Post: 11th March 2007, 00:11
