Thread: Any idea what this is?
    Aug 2011
    Bristol
    Default Any idea what this is?
    I have a wiring loom bracket removed from the engine at prestent and have the below under the bolt that goes up to my bolt for the ignition coil.
    Without the bracket I can't help feeling something is missing. It looks like an ground point but for what?
    Its a metal strip thats runs from right side bolt under ignition coil to right side rear bolt for ignition loom
    Nothing seems to have gone wrong since it has been off.
    Anyone know what it is for and why it goes from my coil bolt to the end of the cylinder head?
    Hanging Heaton
    35 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    Just an earth point iirc... Should have a nut in, that copper strip runs under the coil pack.
    Engine : 1.9 CDTi
    Answered in the other thread asking the same thing
    Aug 2011
    Bristol
    Quote Originally Posted by lee gsi View Post
    Sorry, thought it would get better response in here.
    Do you think it matters that there is no bolt the other end?
    There is no cable that should be attached to the cylinder head end is there?
    Just want to make sure I am OK with the bracket still removed, and trying to make sure it it not causing my misfire (which I doubt).
  1. Any idea if they will fit
    By Hyperhart in forum Vectra C / Signum Car Chat
    Last Post: 28th April 2010, 14:07
  2. Good idea / Bad idea......?
    By david.aka.judas in forum Vectra C / Signum Car Chat
    Last Post: 3rd September 2009, 09:09
  3. superchip good idea or bad idea
    By lewrymyster in forum Vectra C / Signum Car Chat
    Last Post: 3rd July 2008, 19:14
  4. superchip good idea or bad idea
    Last Post: 26th June 2008, 19:09
