Thread: Spacers, spigot rings, alloys.
    Regular Member Lordish's Avatar
    Feb 2012
    Luton
    Default Spacers, spigot rings, alloys.
    I have a set of 18 inch fox RS3 alloys. I needed spigot rings as the centre bore was a touch smaller and they vibrated over 65mph. Put new pads in the front then the back of the alloys rubbed against the caliper. I've bought some 6mm spacers which has solved the rubbing but it now vibrates again when going 65+ as the spigot ring is not doing its job due to the spacer. Any help appreciated.
    Feb 2012
    Luton
    I have a signum pre facelift. Can you but spigot rings that cover more of the hub. I've looked on eBay but could not see any.
    Hanging Heaton
    35 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    You may need some hubcentric spacers, some cheap ones on eBay and the spigot should then go on the spacer, I got some 16mm ones for cheap...
    Feb 2012
    Luton
    Cheers. 50 pounds! Ooh. Will put up with the vibration untill payday. I don't go above 60 anyway ;-). Are these the only option you think? 16 mm quite a big spacer or do you not notice.
    Feb 2012
    Luton
    Also would I need longer nuts? Would 35mm ones be fine.
    Hanging Heaton
    35 Post(s)
    Mileage : 140k
    Yeah as long as you can do more then 5 full turns on a bolt its long enough... You don't need 16 really, but def over 10 to get a lip for the spigot to sit on, if that makes sense...
  1. how much did your spigot rings and bolts cost?
    By hoochydady in forum Suspension, Wheels & Brakes
    Last Post: 21st April 2011, 14:50
  2. spacers ?
    By Wolflinn in forum Styling
    Last Post: 19th January 2011, 12:58
  3. will i need spacers with these?
    By ashleyaluminum in forum Vectra C / Signum Car Chat
    Last Post: 16th June 2010, 16:30
  4. spacers
    By john-d in forum Styling
    Last Post: 13th January 2010, 22:47
  5. Spigot Ring Size
    By redraptor_141 in forum Vectra C / Signum Car Chat
    Last Post: 18th August 2009, 07:37
spigot rings and spacers
