Thread: Where can i buy a new vx or pattern egr valve for 2.2 direct (z22yh) 04 reg
    Jun 2009
    Middlesex
    Default Where can i buy a new vx or pattern egr valve for 2.2 direct (z22yh) 04 reg
    Been trying to buy a new EGR Valve from Vauxhall for my 2.2. Direct (04 reg).They no longer make them so have been trying to buy a new pattern part but still no luck.Can only find the odd secondhand one on EBAY but that seems a bit of a gamble.Can anyone help.
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Strange I just found over 10 suppliers on Google plus my parts supplier also stocks it, @ 200 quid.
    Have you tried cleaning it before buying a new one ?
    PM me your reg number and I can refine the search for you and give you some links.
    Regular Member Paul_NI's Avatar
    Mar 2011
    Northern Ireland
    best bet is it blank and remove, but this needs tech2 updates, but still cheaper than £200
    Jun 2009
    Middlesex
    C-Owner.PM sent.Reg Sent.
    Regular Member Spelly's Avatar
    Derbyshire
    6 Post(s)
    I blanked the one on my 2.2 astra off with a blanking plate and then machined the head off the piston. Looks like an ege but does sod all lol. Cost less than £5 quid to do and no more egr aggro
    Jun 2009
    Middlesex
    Explain a little more about what you did.Is the 2.2 Astra engine a Z22YH the same as in the 2.2.Direct Vectra C. Problem as i have explained is i can't get a new valve from VX because they longer make it,nobody seems to make a pattern, and i'm being told by blanking off the remapping of ECU often does not put out the lights.Wits end what to do.
    May 2011
    South London
    Quote Originally Posted by Dobs View Post
    Sorry for delay been busy.
    This is the part you need and at £40.00 for brand new genuine GM part I would hurry
    Phone to confirm if you like ......... 01625 500400
    http://www.ebay.co.uk/itm/VAUXHALL-A...item3a7e385935
  1. What can u do to a 2.2 direct Z22YH
    By Kcriyback in forum Vectra C / Signum Car Chat
    Last Post: 19th February 2012, 00:40
  2. 2.2 direct z22yh
    By davidlewis24 in forum Engine & Drivetrain
    Last Post: 26th May 2011, 19:34
  3. Z22yh EGR valve
    By tinus71 in forum Engine & Drivetrain
    Last Post: 20th September 2009, 22:16
  4. Z22YH (2.2 Direct) Misfire
    By johnmac in forum Engine & Drivetrain
    Last Post: 16th July 2009, 22:31
