I wanted to fit Bilstien B6's and Eibach Lowering Springs, but was informed that I would loose my ESP. a) would this be a problem. and b) if it was can I fit the Eibach springs on the existing shocks?
Why would you lose your ESP unless you have the IDS setup fitted?
I was told that its pluged into the shock, and that I would loose the ESP if fitting the Bilstien's. I may opt to fit the Eibach springs first and see what that's like
As Yugguy said, the only reason you'd lose the ESP is if you have IDS. Got a sport button on the dash?
thought the signum had the non ids shocks.
