I've just replied to Micky86's latest post - again, sounds like DPF regen - Signum's have these DPFs too. If the smoke is coming out from the front of the car, it may also be a sign of a split flexi-section of the exhaust or split DPF hose to the differential pressure sensor.
As soon as a regen begins (and it won't when you first start the car), more fuel gets delivered in order to heat up the exhaust gases to burn the soot in the DPF, but if the DPF is seriously blocked it can result in back pressure splitting the sensor hoses and exhaust gases can escape from any leaks in the exhaust upstream of the DPF.
If you have the MPG readout, can you see this figure decrease when it begins to smoke? This would be another sign of the regen starting.
