Page 1 of 6 123 ... LastLast
Results 1 to 10 of 58
Thread: help needed starting problem
    Regular Member madmark's Avatar
    great yarmouth
    Default help needed starting problem
    hi all i have a 1.9cdti 2007 it starts fine in the morning when the glowplug light comes on but once i used the car its a right sod to get it to fire up it just turns over and over and trys to fire after about 30 secs of winding it up it fires up in a cloud of smoke ? like i said though fine first thing ?
    Dec 2012
    Midlands
    Recent EGR valve change at all?
    great yarmouth
    dont know mate aint had the car long and no recold of a change ?
    Jan 2012
    Gloucestershire
    Could be the crankshaft sensor. This is the important sensor for starting the car whether cold or warm but I have heard that when the engine is warm that the sensor can fail to function properly - something to do with the heat of the engine affecting the sensor itself.
    Maybe someone else can confirm if they've experienced this.
    great yarmouth
    could anybody else confirm this could be the problem ? thank you dieselwig
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Worn starter motor.
    1. Slow to turn when cold starting.
    2. Slow to turn when hot starting.
    Can be one or the other.
    great yarmouth
    i will keep an eye on starter motor but havent noticed it turning over slowly it seems to turn quick just doesent seem to fire up but will listern to speed of motor when cold and then again when hot and note any change thank you for your reply will let you know how it goes tomorrow cheers
    Regular Member Vectra-c-SRI's Avatar
    May 2008
    Near Glasgow
    Engine : 1.9cdti 8v (120bhp)
    Mileage : 98000
    heard about starting it with the clutch down as it takes pressure off the start motor when cranking.
    great yarmouth
    thanks vectra c sri will also give that a try good point made
    Feb 2013
    Sheffield
    Vehicle : Vectra c
    Engine : 1.9 cdti
    Mine is the same and I think it's the starter on mine. try disconnecting the coolant temp sensor so the glow plugs stay on longer and if it starts straight up then I would say it could be your starter as the combustion will be warm so less cranking needed to fire if not then you may have a different problem
  1. starting problem
    By andrewl6527 in forum Engine & Drivetrain
    Last Post: 28th March 2012, 20:14
  2. Help needed on starting car when cold....
    By abhinn in forum Vectra C / Signum Car Chat
    Last Post: 19th February 2011, 19:41
  3. Starting problem help needed asap
    By stevelee in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2010, 10:52
  4. Problem...? Vectra SXI...problem with starting after filling with fuel?
  5. starting problem
    By chunkster in forum Vectra C / Signum Car Chat
    Last Post: 16th March 2008, 13:09
