Thread: Passed mot, all fine but whats the knock still!
    Regular Member Jow20's Avatar
    Sep 2010
    Leeds
    Default Passed mot, all fine but whats the knock still!
    So its not arb links or track rod ends or suspension, so what else can it be!? When the car is on ramp its all solid! But uneven/bumpy roads, its knocking from front end! Its on 35mm apex springs. Cheers
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    A common knocking point is supposed to be radiator top mounts... tucked away under the slam panel .... something I need to look at myself (when it's not baltic outside).
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 167340
    droplinks?
    Sep 2010
    Leeds
    No drop links an rubbers are fine ste, tested at mot. How would you test the radiator top mounts? Anywhere to pull on it etc..?
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    Shock absorbers can knock, but appear fine on a ramp.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 167340
    Quote Originally Posted by Jow20 View Post
    http://www.vectra-c.com/forum/showth...unts&p=1990743
    http://www.vectra-c.com/forum/showth...iator%20mounts
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    You can never replicate the forces from the weight of the car while one a ramp, so a joint that is only started to wear won't be detected straight away - so you can't really rule anything out just because its been for an MOT.
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Top mounts - or steering arms.
    Middlesex
    Trim : SRI
    Mileage : 100k
    ....or inner cv joints..
  1. Help Needed Please...Knock knock...
    By wishy1976 in forum Suspension, Wheels & Brakes
    Last Post: 23rd March 2012, 00:34
  2. Knock, Knock, Knocking...
    By Carmaduk in forum Suspension, Wheels & Brakes
    Last Post: 25th May 2011, 22:20
  3. Replies: 2
    Last Post: 29th January 2010, 11:51
  4. Knock Knock whos' there
    By lizard in forum Suspension, Wheels & Brakes
    Last Post: 8th November 2009, 21:18
  5. Knock Knock Knockin on heavens door
    By lizard in forum Engine & Drivetrain
    Last Post: 17th January 2009, 00:10
