Thread: Hubcentric wheel spacers
    Oct 2012
    peterlee
    Default Hubcentric wheel spacers
    Hi im thinking of putting spacers ( with extra long bolts) on . I have an facelift sri with the 17 inch wheels which i quiet like the look of , but think they sit a bit too far inside the arches ,i have two question
    1) are the hubcentric type ( 5x110 with 65.1 bore) any good safety wise ? And
    2) with standard sri setup would i be able to put 12mm spacer on ?
    thanks in advance
    Regular Member Jow20's Avatar
    Sep 2010
    Leeds
    Yes perfectly fine with standard sri setup, and they are safe. The hubcentric spacer bolts on the hub and the wheel bolts into spacer. I have 25mm ones
    Oct 2012
    peterlee
    Excellent will be ordering a set , how close are 25mm to the arch edge ?
    Hanging Heaton
    24 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    If your undecided on size yet get some string with a weight on and place it inside the arch, you can get an exact measurement and know how far you can go
    Sep 2010
    Leeds
    25mm sit my 19" snowflakes out just right. (Only on rears) the sri wheels are only 7" wide so dont be shy to get more than 12mm ones!
    Regular Member stephen_brady's Avatar
    Jan 2012
    N.Ireland
    Interested if you ended up doing this as I'm currently considering it, so some pics would be good.
    Jun 2009
    South Coast
    8 Post(s)
    Vehicle : Insignia
    Engine : 1.6T SIDI Petrol
    There are plenty of threads with pics of members cars with spacers and links to the items they bought.
    Jan 2012
    N.Ireland
    I did do a search, that's how I found this. Didn't see any on 17's though!
    Hanging Heaton
    24 Post(s)
    Mileage : 140k
    Doesn't matter about wheel size as the diameter is roughly the same, as I said above use a plum line to get the mm you need due to different widths... The 2.2 link below in my sig shows mine, I think?
  1. wheel spacers
    By decks in forum Suspension, Wheels & Brakes
    Last Post: 5th June 2012, 20:55
  2. wheel spacers
    By decks in forum Vectra C / Signum Car Chat
  3. Wheel spacers
    By vxpenfold in forum Handling & Braking
    Last Post: 5th February 2012, 10:45
  4. wheel spacers , has anyone?
    By melvyn8181 in forum Styling
    Last Post: 12th October 2011, 10:26
