Thread: improving mpg ,not using 6th?
    Regular Member mrk's Avatar
    Vehicle : vectra hatchback
    Trim : improving
    Engine : 1.9cdti mas remap
    Year : 06
    Default improving mpg ,not using 6th?
    read a few comments on here about mpg increasing by not using 6th gear,i assumed 6th gear reduced revs there by using less fuel.any thoughts or experiences of mpg increases welcome
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    I understand the theory. If the engine is labouring in 6th it will use more fuel, therefore 5th would be the better gear to be in.
    Jul 2011
    UK
    Year : 06
    so if am cruising at 70 in 6th it using more fuel than being in 5th using more revs how does that work
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    24 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    I would have thought that if your motoring along at 70 then the engine wouldnt be 'labouring'..6 th at that speed drops my 2t to APPROX 3k revs..
    Regular Member rockafella8587's Avatar
    Nov 2011
    Akrotiri, Cyprus
    If you are doing maybe 50mph then that is too slow for 6th gear to be efficent, so 5th would be more economical as the engine would not be labouring. But motorway speeds then 6th will be the optimal gear. So maybe the 5th gear tip is most suited to a and b roads. I have noticed this is true and I alway try to match my gears to my speed so the engine doesnt labour. Just play around and you will get a feel for it
    Regular Member Greebo's Avatar
    Jan 2012
    In Limbo
    under 70 i use 5th if i go to 70+ then 6th is used, i found that the engine labours just that bit more in 6th than 5th at 60
    South east
    Apparently the engine is operating most efficiently at the point of maximum torque (torque, rather than BHP). if true, then obviously the RPM at which 6th is more efficient than 5th depends on which engine you have, so refer to a torque graph for your engine and see where torque reaches its peak.
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 85000
    Quote Originally Posted by Rebellion View Post
  1. Improving black paintwork
    By Jonsey in forum Detailing and Car Care Discussion
    Last Post: 14th May 2011, 10:35
  2. Improving my Power?
    By JDX-SRI in forum Tuning
    Last Post: 29th January 2010, 11:51
  3. Improving the look of my bum
    Last Post: 8th March 2008, 14:49
  4. Been looking at improving the brakes
    By The Doc in forum Vectra C / Signum Car Chat
    Last Post: 25th April 2006, 10:14
  5. Economy improving with age and mileage
    By Breezy boy in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2005, 11:49
