Thanks Thanks:  1
Results 1 to 10 of 19
Thread: Injector Values
    Oct 2010
    Birmingham
    Default Injector Values
    My 05 1.9CDTi (120) Vec C is mis-firing. A mate at work put the op-com on it on Friday to read the values of the injectors - Number 2 was constantly at +5, the others varied.
    What are the optimal readings that they should be at? I have searched all over the web and various forums so was wondering if anyone knows what they should be. I think I will be replacing each one, but want to know which ones to replace so if anyone has the values they should be at when the op-com is on that would be great!
    Matt
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Quote Originally Posted by bigmatt View Post
    Matt
    Think there supposed to be within -3/+3 but not 100% sure as thats for the 150 ps, remove injector plugs & spray with elec contact spray to see if there's any difference.
    Jan 2012
    Gloucestershire
    I've never understood this. How does the ECU know to inject different amounts from each injector during the life of the injector? I know that injectors are tested at a test facility prior to fitting to an engine and can have fuelling corrections programmed into the ECU based on the injectors performance as new, but once installed, how does the ECU recognise individual injector performance? I can understand that various sensors can inform the ECU of different conditions, such as intake pressure, pedal position, temperatures etc., but what tells the ECU to instruct the injectors to deliver more/less fuel on an individual injector/cylinder basis?
    I know I've asked similar questions before and have been told that knock sensors can see this, but I didn't think the 1.9cdti had knock sensors - could be wrong.
    Any info would be great.
    Quote Originally Posted by DieselWig View Post
    I think the crank angle/position sensor is fast enough for the computer to measure the acceleration of the crank with each combustion stroke. If say cylinder 1 has less acceleration than the others it will add more fuel to injector 1 to compensate.
    Jan 2012
    Gloucestershire
    Maybe the camshaft sensor then? If it has sufficient resolution to detect speed change during a revolution (which maybe it has to have for injection start of injection timing), then this would make sense. Can anyone confirm this is what happens?
    I would have thought crank angle would be higher resolution than cam because there are 720 degrees of rotation to every 4 stroke compared to only 360 degrees at the cam?
    Piston acceleration is one possibility however I also found this info in dieselclass.com.
    http://dieselclass.com/Fuels%20Files/Common%20Rail%20High%20Pressure%20Fuel%20Injection %209-2010.pdf
    "Zero Fuel Mass Calibration (ZFC)
    Just as mechanical manufacturing tolerance for injectors requires changes to injector
    energizing time, injector wear also changes injector operating characteristics. Injector
    deterioration contributes to increased emissions calling for a re-calibration of the stored
    correction factors which compensate for unique operational behavior. Without a strategy
    to recalibrate an injector, a vehicle could pass out of compliance with emission standards
    and emission system durability requirements. The process of recalibrating injectors
    during service is called Zero Fuel Mass Calibration (ZFC)
    One common technique for accomplishing ZFC correction occurs during vehicle
    deceleration. Calibration occurs when the engine is driven only by the vehicles kinetic
    energy and no fuel is injected into the cylinders. Fuel rail pressure is adjusted to a
    specific value. With no movement of the throttle position sensor from idle position and
    the engine in an over run condition, the ECM will begin to increase energization time to a
    single injector. When a measurable engine speed increase is detected, the ideal energizing
    time stored in the ECM based on initial calibration codes is compared to the actual time
    to produce the engine speed change. Mathematical comparisons made between the two
    values result in a change to stored correction factors. Each time the conditions for ZFC
    are met, another injector is recalibrated."
    However if with Op-com or a scanner the ECU can be seen adjusting the injector correction factors at idle then it can't be ZFC and must be based on piston acceleration.
    Some more good info (basically a 2 part article on common rail system):
    http://www.autospeed.com/cms/A_108104/article.html
    http://www.autospeed.com/cms/article.html?&A=108105
    The latter (part 2) describes "smooth running control" which is basically the adjustment of individual injector quantity using engine speed. Crank sensor provides the speed and cam sensor tells the ECU where the engine is at in the firing order (so it knows which injector to adjust).
    Jan 2012
    Gloucestershire
    Great info, thanks jonnyaykroyd - and yes, you're 100% correct, crankshaft sensor would make more sense for detecting speed variability - I wasn't thinking straight.
    If this is indeed true of the 1.9cdti, then maybe bigmatt's #2 injector is playing up - not that I doubted the-wizard, just that I wasn't sure how the ECU could know. Sorry for hijacking your thread bigmatt
    Oct 2010
    Birmingham
    Hi,
    I managed to get my Op Com and below are the values at 850prm approx and 2000rpm approx
    It would appear No 2 is stuffed - what about the others they look constant!
    It's interesting how number 2 hardly varies at all with the change in load/rpm, whereas the others vary 0.3-0.5mg/stroke.
    Maybe 5mg/stroke is max correction that can be applied.
    On the basis that it's trying to add more fuel (and lack of fuel is the cause of your misfire) i'd be looking at checking 1) Injector wiring continuity - could be a high resistance fault, or 2) try a DIY injector purge/clean: http://www.youtube.com/watch?v=DuTTb_acdxs
    With the clean you basically run the engine off the cleaner (which is something like 60% diesel). To do this you have to loop the fuel out line from the fuel filter straight back to the fuel tank via the fuel return line so the lift pump in the tank can still run and you don't spray diesel everywhere.
    I can't understand how 3 out of the four injectors look in perfectly serviceable condition (based on the correction factors you've got) but number 2 is bad. Definitely triple check your wiring. I don't know if this can happen on the Z19DT but on the Z19DTH the injector wiring terminals within the plastic connectors fail - i have a video on youtube showing this: http://www.youtube.com/watch?v=xyhkW0lXoDg
    Is you're missfiring constant? or intermittent?
  1. reading injector values opcom
    By james walker in forum Vectra C / Signum Car Chat
    Last Post: 7th February 2012, 15:07
  2. Vectra c 1.9 8v Opcom Injector values
    By zippygsi in forum Engine & Drivetrain
    Last Post: 25th November 2011, 20:26
  3. Injector Wiring Loom (common fault on 3rd injector)
    Last Post: 8th October 2010, 12:18
  4. emissions values for 2.2 Direct
    By DaveG in forum Engine & Drivetrain
    Last Post: 3rd April 2010, 15:07
https:www.vectra-c.comforumshowthread.php182269-Injector-Values
opel vectra 1.9 cdti 88kw proper fuel injector correction dose
are z19dth injectors coded by cylinder or firing order
vectra c 19 cdti cylinder order
astra h opcom injectors correction
1.9 dth injectors values
opel 1.9 injection tolerance
resistance reading for 8v astra injector
vectra c 1.9 cdti injector opcom quantity
1.9 cdti fuel injection amount
vectra c cdti emission value
op com fuel injector test
Final fuel injection amount for opel vectra
opcom final fuel injection amount
z19dth injector deviation
Zafira Vauxhall 1.9cdti 2007 how much power do injectors have
z19dt 2000 rpm sensors readings
vectra c 1.9 cdti 88 kw emissions values
opel vectra c 1.9 cdti 88kw injector fuel return value
which is number 1 cylinder z19dth
vectra injector correction values
Injector readings 1.9 cdti
1.9 cdti injector value
do 1.9cdti injectors need to be installed via op com
1.9 cdti rpm values
