Thread: no power help????
    May 2012
    wirral
    Default no power help????
    ok people need help (again) , car started losing power between 1000-2000 revs gradually got worse until barely driveable especially when cold , i know there is threads covering this but i need help still. its 1.9 cdti 150 2006 , ive changed the egr valve , fuel filter , glow plugs , hasnt made one bit of difference still no power until 2000 plus revs then its goes like a train.the swirl rods are still connected on inlet. im totally baffled any help appreciated please..
    oh and also no eml or car/spanner light is lit up all is fine with dash lights still
    cheers
    Carnoustie
    Did you fit new egr? Checked the boost sensor, and vacuum pipes
    Ronnie
    May 2012
    wirral
    Quote Originally Posted by ronnie63 View Post
    Ronnie
    yea i fitted new egr ? and about two months ago i changed the two vacuum pipes by the front right side of engine about 6 inch long ? to be honest not sure about other pipes , were will i be looking , any images ?
    Carnoustie
    Boost sensor is bolted beside egr black thing with one torx bolt
  1. Replies: 17
    Last Post: 11th March 2015, 00:55
  2. Signum Sluggish low power, Limp mode at high power.
    By Bigg943 in forum Vectra C / Signum Troubleshooting
    Last Post: 6th June 2011, 18:55
  3. Signum Sluggish low power, Limp mode at high power.
    Last Post: 5th June 2011, 11:30
  4. Replies: 11
    Last Post: 7th January 2010, 17:50
  5. Power Steering Electrical Power Drain
    By AntB in forum Suspension, Wheels & Brakes
    Last Post: 1st November 2007, 16:03
