Thread: Signum Fog Lights
    Dec 2012
    Benfleet
    Engine : 1.9CDTi 150
    Default Signum Fog Lights
    Guys,
    been searching this for a while but unable to come up with a definitive answer!!
    i have a 54 plate (05 model year) Signum Design 1.9CDTi 150, when i bought it it had foglamps fitted and i never checked that they worked, on testing them they don't!!
    the wiring is all there, i've activated them in the UEC and the light on the dash now activates when i press the button, but i now get check warnings for both front fogs and they don't come on. do i need to activate them anywhere else? or am i missing something??
    Thanks in advance!
    Essex
    29 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    Mileage : 97000
    I,m guessing the bulbs actually work ???
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    or that there are actually bulbs in the units.
    Dec 2012
    Benfleet
    Sorry, not been on forum for a while as been busy working.
    Yes, both units have lamps fitted and both lamps have been check as working, but thanks anyway.
    Seen another post about Vectra C fog light saying to check UEC for connections to pin 10 & 37 so guess that's my next step. then it'll be actually checking continuity of the cables from one end to the other to make sure that they are actually connected all the way through!!
    Just an after thought but what fuses cover the front fogs as can't find it in the manual??
    Dec 2012
    Benfleet
    update to this!!
    Car was fitted with fogs as standard acording to equipment check with ecat24.com
    When i got the car the front fog button had no effect when pressed (no symbol on dash) i've had it set to present in the UEC and now get lamp check all the time and the symbol illuminates on pressing the button, i've checked the loom from the connector in the bumper out to each fog light and all is OK, just not getting volts down to plug!!
    HELP!!
  1. Signum lights help please
    By Guinea in forum Electrical & ICE (including SatNav)
    Last Post: 11th October 2011, 22:09
  2. Signum reverse lights
    By 111 in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2011, 18:58
  3. signum fog lights
    By Tucker in forum Vectra C / Signum Car Chat
    Last Post: 20th July 2010, 08:50
  4. signum fog lights to a veccy
    By AL21784 in forum Styling
    Last Post: 6th July 2007, 16:19
