Results 1 to 10 of 18
Thread: LPG - Spark Plug Advice ?
    North West - Assistant RO Woody's Avatar
    May 2012
    North West (Warrington)
    239 Post(s)
    Vehicle : Vectra C 3.2 Elite Estate Auto Facelifted
    Trim : Elite with loads of "Extras"
    Engine : 3.2 Z32SE
    Mileage : 94,000
    Default LPG - Spark Plug Advice ?
    Hi to the LPG fraternity
    Ok, I got my car ready converted just under a year ago. Now I am working on getting a full service done, including filters and spark plugs. After that, I'm going to get the car checked over by an LPG service agent (filter/safety).
    So, can I have some suggestions as to the "best" type, make of Spark Plugs I should be using ?
    I have a 3.2 preface (not that I would think should make much of a difference compared to facelifts) and an auto box.
    I can see "Iridium" plugs all over ebay, but am sure most of that and the price is "hype".
    So, can you help with some useful replacement spark plug advice fellas ?
    Woody
    South West
    I lookedinto this to see if it would make any difference. Pretty much everyone with any real knowledge said keep using the ones recommended by the manufacturer.
    Ones which claim to offer better mpg etc are just not worth the money. Just my findings when asking the same as you.
    BTW I always used NGK ones in my 2.0 T
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    when I had my LPG converted 2.0 vectra B I went to the dealer & they supplied standard plugs .
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    I'd see what the LPG guy says tbh, its a specialist area and no dealer is going to know anything about it.
    May 2012
    county durham
    Mileage : 145k
    as many of the dealers will have supplied dual fuel cars they should have a pretty good idea , of then again maybe not
    Regular Member veclee's Avatar
    Nov 2012
    skegness
    Vehicle : vectra c
    Trim : club
    Engine : 1800
    Mileage : 63000
    Lpg burns alot hotter then petrol standard plugs arnt really up for the job ngk do a plug that operates at a hotter temp than standard ones hence works better and a less likely chance of breaking down due to faulty burnt out plugs I've owned several 4 litre Lpg jeeps before and found saving a fiver by buying standard plugs don't work in the long run
    Leicestershire
    Trim : PreFace SRi
    Engine : 1.8 LPG
    Year : 53
    i got these for my 1.8 dual fuel last year:
    http://www.ebay.co.uk/itm/4x-NGK-LAS...item2573c4d358
    i've always used NGK and have alot of faith in them. These sparks worked better than ordinary spark plugs in my opinion.
    May 2012
    239 Post(s)
    Engine : 3.2 Z32SE
    Mileage : 94,000
    Thanks fellas, your input is much appreciated
    Regular Member DanBristol's Avatar
    Jan 2013
    bristol
    i was at Avon Auto gas the other day .. the guy there told me to ring NGK and they will tell you the correct plug over the phone
    May 2012
    239 Post(s)
    Engine : 3.2 Z32SE
    Mileage : 94,000
    I've been told that NGK only sell one plug specifically aimed at LPG, and that is their LPG1 model.
  1. Spark Plug & Sump Plug Torque setting - Z18XE Engine
    By wafoo in forum Engine & Drivetrain
    Last Post: 4th June 2012, 21:15
  2. Spark plug replacement 2.2.direct (z22yh) advice.
    By Dobs in forum Engine & Drivetrain
    Last Post: 12th February 2012, 18:32
  3. Spark Plug Gap
    By Gogs67 in forum Engine & Drivetrain
    Last Post: 23rd September 2009, 08:40
  4. Spark plug gap
    By gibbon7000 in forum Vectra C / Signum Car Chat
    Last Post: 14th April 2009, 20:45
  5. Spark Plug Advice Needed for GSI 3.2
    By gsi32 in forum Engine & Drivetrain
    Last Post: 21st November 2007, 11:41
