Results 1 to 10 of 28
Thread: so I havw just bought hid's, now need side light advice@!!
    Regular Member nath-lav's Avatar
    Mar 2011
    newcastle upon tyne
    Default so I havw just bought hid's, now need side light advice@!!
    As above I have just purchased hid'S 6000k and need some side light bulbs to matche... (which wont set off error codes and will be a direct replacement) any help with links to ebay much appreciated quick
    North West - Assistant RO Woody's Avatar
    May 2012
    North West (Warrington)
    239 Post(s)
    Vehicle : Vectra C 3.2 Elite Estate Auto Facelifted
    Trim : Elite with loads of "Extras"
    Engine : 3.2 Z32SE
    Mileage : 94,000
    Side lights ? Hope you're not thinking of LED's ? If you are, then you are opening up a minefield of experiences.
    Why don't you just do a "search" on the forum, there must be hundreds of threads on this ?
    Basically, Vectras don't work too well with LED's which are not really bright enough anyway to work as side-lights IMO. You will have to deal with bulbs that don't light the road too well, bulbs that trigger failure warning messages, and bulbs that strobe when they are off but when you are driving.
    So ordinary bulbs are probably best, and as for which types, just do some searching on the forum using the search function fella HTH
    Woody
    Mar 2011
    newcastle upon tyne
    Cheers pal, and am looking for any bulbs thsts going to match your the 6000k tbh. ..any thoughts???
    May 2012
    239 Post(s)
    Engine : 3.2 Z32SE
    Mileage : 94,000
    Well fella, having seen (or rather I didn't see them because they weren't at all bright in daylight) some LED varieties, I chose these bulbs for mine.
    Don't get too excited fella, they are only sidelight bulbs after all , but they were brighter in daylight than the LED's on the other Vectras I compared with, and they don't strobe (because they are genuine bulbs) Forget any reference to Renault, these work fine fella and the sellers stock the self same bulbs for all car models, just different codes at the same price, I spoke to them on the phone and got these for my Gsi -
    http://www.ebay.co.uk/itm/3803925369...84.m1439.l2649
    Cheers and happy ebaying matey
    Woody
    Mar 2011
    newcastle upon tyne
    Appreciate it maate, but have you got link for bulbs to fit vectra c, abd will it nit bring any errors up, thanks
    May 2012
    239 Post(s)
    Engine : 3.2 Z32SE
    Mileage : 94,000
    See the above post. Those bulbs will be fine in your motor fella. Got them in my Vectra 3.2 Gsi and they are fine (definitely NO ERRORS because they are Bulbs NOT LED's).
    Mar 2011
    newcastle upon tyne
    Are spot o mate, so even tho they are for renaault they will fit my 1.9 cdti? So fir the hasstle
    Regular Member JM53 BEL's Avatar
    Oct 2012
    Clackmannan, Scotland
    Trim : Elgance
    Engine : 2.0 Turbo
    Mileage : 106000
    What kit did you buy? Hids i mean,
    May 2012
    239 Post(s)
    Engine : 3.2 Z32SE
    Mileage : 94,000
    Quote Originally Posted by nath-lav View Post
    Try to imagine changing the 100 watt bulb in your living room fella. The guy next door has the same bulb but a different living room.
    The important bit is the bulb type. In your case a W5W bulb for sidelights. Any W5W bulb should work no problems, it's only the colour of the light you are interested in, and also if it an LED , or a standard bulb.
    The one I posted a link to is what I bought and fitted to my car fella, and it isn't a "bad light colour" compared to my HID's either and is a standard bulb too
    HTH
    Woody
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Woody when your down ill show you my side lights see if you still agree that their not as bright lol
    ive got 15 tower smds as side lights and they've got to be at least 5 times as bright as standard bulb
    granted they flash when turned off but I always drive with car in atleast side lights so not too fussed
  1. HID's fitted, now an emissions light!!
    By Vectra_Power in forum Electrical & ICE (including SatNav)
    Last Post: 3rd February 2010, 19:19
  2. HID's - Advice needed
    By jamesgsi1983 in forum Electrical & ICE (including SatNav)
    Last Post: 18th July 2009, 00:14
  3. Bought this, need advice for fitting/painting
    By ronnie63 in forum Styling
    Last Post: 7th June 2009, 10:21
  4. HID's Installed - Now got Engine Management Light on
    By mickyd98 in forum Electrical & ICE (including SatNav)
    Last Post: 26th February 2008, 16:36
  5. arghh side light problems warning light
    By Gregg in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2008, 21:58
