Results 1 to 10 of 13
Thread: Boot release Signum
    Regular Member stuk2000's Avatar
    Horncastle
    Default Boot release Signum
    Does anyone know where I can get the boot release catch (the electric bit) from. Mine doesnt work?? Or is there a fuse??
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    Have you tried cleaning the microswitch?
    Horncastle
    not yet, only got the car yesterday, when you press the button on the drivers door it beeps but nothing happens on the boot??
    East Kilbride
    Engine : 3.2 v6
    Mileage : 140,000
    What Das said, common problem.
    3.2 v6 Signum and loving it 😁
    Vehicle : Jaguar S-Type V6
    Trim : Sport
    Engine : Petrol
    give it two sharp blows with the side of your fist in the lock area it should open. failing that climb inside and open it using the slot with your key/screwdriver. once open you will need to clean the micro switch mechanism. the plate can stick.
    PS the rubber cover is a pain to get back in.....
    Regular Member Keif's Avatar
    In the Garage
    Quote Originally Posted by stuk2000 View Post
    The button on the drivers door doesn't "open" the boot. It just unlocks it.
    Are you saying it doesn't unlock the boot (the beep) or does the tailgate release (above the numberplate - between the numberplate lights) not work?
    Horncastle
    the tail gate doesnt release, it beeps. but when you go to press the button above the reg plate nothing happens?
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 85000
    Yea definitely sounds like the microswitch, the button is not activating the switch to power the latch to unlock.
    Trim : Sport
    Engine : Petrol
    If the plate is stuck in the up position against the micro-switch then nothing will happen.
    In the Garage
    Quote Originally Posted by Das View Post
    I agree with Das.
    Have a search, there's a thread on here with photos how to sort exactly the issue you're having.
  1. Boot Release
    By stuk2000 in forum Electrical & ICE (including SatNav)
    Last Post: 29th January 2015, 18:47
  2. Testing the boot release switch on a Signum (Pictures)
    By lee gsi in forum Vectra C / Signum Car Chat
    Last Post: 20th February 2012, 11:53
  3. Signum boot release
    By dave_3 in forum Electrical & ICE (including SatNav)
    Last Post: 16th January 2011, 13:33
  4. Signum Emergency Boot Release
    By O5prey in forum Vectra C / Signum Car Chat
    Last Post: 5th April 2009, 23:44
  5. Boot Release
    By Drew in forum Vectra C / Signum Car Chat
    Last Post: 8th February 2009, 22:34
boot release beep vauxhall
vectra c emergency boot release site:www.vectra-c.com
