Thread: fan kicking in straight away
    Regular Member coooky's Avatar
    May 2011
    washington
    Default fan kicking in straight away
    when i start the car the fan starts straight up
    i started it today and let it run for a few mins turned it off and the fan ran for maybe 30 seconds after the engine was off
    the glowplug light is taking about a min to go out so im going to changed them but any ideas on the fan ??
    thanks
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Check the connections to the fan, and also the fuses for it.
    As, if you disconnect it, the fan will run all the time (like yours is). So sounds like an electric issue somewhere.
    Chelmsford
    Faulty temperature sensor would be my bet.
    May 2011
    washington
    Quote Originally Posted by DNS View Post
    any link for a new part ??
    thanks
    May 2011
    washington
    changed the sensor twice now the temp gauge wont go up the fan kicks in straight away and runs for a few mins when the car is turned off
    and the engine if revved over 4k starts bouncing all over and sometimes at standstill it starts to jump around
    any ideas
    Regular Member ftm100's Avatar
    South Shields seagull sh*t town
    Fans run when temp senors is disconnected so could point to break in wiring
    May 2011
    washington
    thanks
    that should be fun to look for lol
    would it still run when the car is turned off
  1. Steering wheel not straight, but car drives straight?
    By Danny.surname in forum Suspension, Wheels & Brakes
    Last Post: 24th February 2013, 00:21
  2. car kicking out smoke
    By coooky in forum Engine & Drivetrain
    Last Post: 19th August 2011, 20:47
  3. Back end kicking out
    By Juego in forum Handling & Braking
    Last Post: 29th April 2011, 22:06
  4. Engine fan is not kicking in
    By charlie in forum Vectra C / Signum Troubleshooting
    Last Post: 4th August 2009, 01:35
  5. I bet hes kicking himself now...
    By rob 2.2dti in forum Comedy & Humour
    Last Post: 10th February 2009, 20:09
