Thread: Estate Owners and GPS
    Regular Member greeningr's Avatar
    Jan 2006
    Oswestry
    Question Estate Owners and GPS
    I hope someone can help.
    I've decided that I heed to put an external GPS aeriel in the vec estate as whilst in built up areas (cities) I loose Sat Locks, which is a real pain.
    I have the aeriel and I'm after some thoughts on where is the best place to locate the said aeriel, and how to route the cable to the GPS which is located on the dash over the left centre airvent.
    I think the aeriel has about 5m of cable so location shouldn't be a problem.
    Any help will be gratefully recieved and if their is any pictures all the better.
    Hertfordshire
    My estate is wired and positioned the same as my hatch was.
    Routing cables through the bulkhead on the Vec C is really easy. There is a large rubber grommet in both (N/S & O/S) top corners, and you can easily put cables through here, the N/S is easier to get to as you can just pop the glove box out and it gives you loads of room. But mine actually uses the O/S as my cable was not long enough to go the other way.
    The receiver itself is mounted on top on the front crumple bar thingy, so the receiver sees through the plastic bumper. It is just stuck on using very strong double sided sticky foam pad stuff.
    Jan 2006
    Oswestry
    GG: I hadn't thought of putting it their. Looks a good place to me will have to investigate that.
    Next question - How do you remove the glove box?
    Has anyone got any other suggestions?
    Feb 2006
    Dorset
    double side it up in the top corner of the screen
    Feb 2006
    Dorset
    glove box is 5 t20 torx to remove , 3 across the top 2 at the bottom
    the grommet is huge , you can get a corsa through it ,
    Hertfordshire
    Quote Originally Posted by DennisTheMenace View Post
    Yep, what he just said.
    It's an excellent place I think, unless you crash, lol.
    Jan 2006
    Oswestry
    Quote Originally Posted by Green Growler View Post
    I've no intention of crashing and the aeriel's are only £20 so not bothered if do have a crash and it get damaged.
    Now to find some free time to do this and get a Torx screwdriver
    Thanks everyone
    Jul 2006
    How come the plastic doesn't interfere with reception?
    Feb 2006
    Dorset
    GPS like GSM can see through plastic as its non metallic ,
    Regular Member In a states's Avatar
    Dec 2005
    In an estate car
    I run mine under the ciggarette lighter in the centre console between the seats.
    Using a Holux 236 I think...works a treat.
  1. for 1.9cdti 150 estate owners only
    By solorider in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2009, 11:25
  2. estate owners
    By lilangel in forum Vectra C / Signum Car Chat
    Last Post: 23rd March 2008, 19:57
  3. 1 for estate owners
    By greeningr in forum Vectra C / Signum Car Chat
    Last Post: 1st June 2006, 14:54
