Results 1 to 10 of 15
Thread: Swapped frip key case, key opening a bit limp....
    Regular Member Desolation91's Avatar
    Jan 2013
    Chesterfield
    Trim : Elite, Tan leather
    Engine : 1.9 CDTI
    Mileage : 106000
    Default Swapped frip key case, key opening a bit limp....
    Afternoon all!
    Fitted my new key case today and in don't think I've got the spring right. In the original there is a little nick that's not there in the copy... Do I just add that in or is there something I'm missing..
    http://static.photobucket.com/player...ps336c59c7.mp4
    North West - Assistant RO Woody's Avatar
    May 2012
    North West (Warrington)
    240 Post(s)
    Vehicle : Vectra C 3.2 Elite Estate Auto Facelifted
    Trim : Elite with loads of "Extras"
    Engine : 3.2 Z32SE
    Mileage : 94,000
    I had similar problems the first time I tried to assemble one of these.
    I think I found that 3 complete turns of the spring were the ideal -pre-tensioner needs, then I found the blade locking pin was protruding ever so fractionally from one side (and catching on the plastics), it just needed "tweaking" so it was perfectly flush.
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    Mine is the same and same case it pees me off i think i need a new one but a better one.
    Jan 2013
    Chesterfield
    Engine : 1.9 CDTI
    Mileage : 106000
    There is no nug missing to hold the spring shall I put one in so I can turn it? Which way to turn?
    Si
    May 2012
    240 Post(s)
    Engine : 3.2 Z32SE
    Mileage : 94,000
    Well mate, the one I have is a Chinese copy used to convert from a non flip to flip, has a lug on it.
    I can't see how it can work without one really, however, it may be that you haven't understood its design properly perhaps ?
    If you have, then it either appears to be missing a vital part, or is faulty IMO.
    If I were you I would be contacting the seller and asking for a replacement now mate.
    Jan 2013
    Chesterfield
    Engine : 1.9 CDTI
    Mileage : 106000
    Sorted just cut a little nug did 2 turns you know which is the right way cause the wrong way springs it closed! and wow its on viagra now! Blink and you miss it!
    http://static.photobucket.com/player...ps2009163c.mp4
    May 2012
    240 Post(s)
    Engine : 3.2 Z32SE
    Mileage : 94,000
    Glad you got yourself sorted fella
    Jan 2013
    Chesterfield
    Engine : 1.9 CDTI
    Mileage : 106000
    Yeah cheers. Have you glued yours closed? You could try winding yours?
    May 2012
    240 Post(s)
    Engine : 3.2 Z32SE
    Mileage : 94,000
    Mine is fine mate. It's the flip key conversion variety so is screwed together rather than glued (you need to take it apart to change the battery). A slightly different design and a fraction larger with no slide off battery cover, but at a quick glance looks 100% original and works very well indeed
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    Its mine that feeked i need a new one the spring in mine is all twisted so new one needed.
    Got a link to the ones you got?
  1. Swapped
    By stuk2000 in forum Vectra C / Signum Car Chat
    Last Post: 24th February 2013, 09:58
  2. For Sale: Galaxy S3 Box,charger,Ear phones,Battery Team gb case,leather flip case
    By bigmac in forum General items for sale
    Last Post: 30th December 2012, 22:03
  3. Just swapped my 2.2 petrol for 2.2 DTI
    By Rennie in forum Vectra C / Signum Car Chat
    Last Post: 2nd May 2010, 12:20
  4. Just swapped my insurance over.....
    By PAULMAC77 in forum General Chat
    Last Post: 19th March 2009, 10:56
  5. Swapped the Signum for a Jag.
    By SCOTTEX in forum Detailing and Car Care Discussion
    Last Post: 4th January 2008, 22:57
