Results 1 to 10 of 15
Thread: The common steering wheel vibration at speed fault.(FIX).
    Vehicle : Jaguar S-Type V6
    Trim : Sport
    Engine : Petrol
    Default The common steering wheel vibration at speed fault.(FIX).
    If you have a steering wheel vibration at speed and have had numerous wheel balances without any change try the following:
    I had this very problem with my Signum from when I picked it up. I tried having the wheels balanced but this was to no avail!
    While doing some routine maintenance checks I found some play in the wheel from the 3 & 9 O'clock axis. I replaced the inner Tie rods, tie rod ends and the front ARB bushes. I then re-set the tracking, took her for a spin and found the steering to be firm responsive with no vibration at all!
    Happy days
    Parts = £67 inc vat.
    No Vibration = priceless £££££££
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    Engine : 1.6T SIDI Petrol
    inner tie rods, is that an easy enough home job?
    Trim : Sport
    Engine : Petrol
    Yeah, done mine with no problems.
    Grantham, Lincolnshire
    63 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Doing inner tie rods, track rod ends and front lower arms on mine tomorrow hopefully if we have time after doing some work on someone else's car first (got all the parts sat here to do it). As my steering's got very loose and floaty recently.
    Trim : Sport
    Engine : Petrol
    Loose and floaty steering! Mine was like this when I first test drove the car after fitment of the new parts. I found it was due to the tracking. It was toeing in! After the tracking was reset the response is crisp and true.
    63 Post(s)
    Year : 2010
    Nah, mine was absolutely rock steady previously, went round corners on rails and drove like a sports car (mind you I spent £1300 on the suspension to get it that way). It had been getting a little looser and I'd noticed it and at my last M.O.T. I got an advisory for the tie rods and track rod ends, so they're all bought now and waiting to be fitted and hopefully it will all be back to normal after a re-alignment.
    Regular Member stephen_brady's Avatar
    Jan 2012
    N.Ireland
    I have this vibration issue. Since I got new tyres fitted I have had them balanced at 3 different places with no avail. Although, other than the vibration I have no other steering problems. Is the any way to visually check the tie rods and track rod ends before I take the plunge?
    Nov 2010
    East Midlands
    8 Post(s)
    Trim : design
    Like the Op said - jack a front wheel up grab the wheel at the 3 and 9 o'clock position and rock it to see if there is any free play/movement in the joints. Your steering wheel should move at the slightest movement of the road wheel. You can also get underneath and while the wheel is raised off the ground, take hold of the track arm and try and move it around watching to see if there is any movement at either end joints - although this can be difficult to detect with the weight of the wheel/suspension hanging on the joints. You should also do this check with the wheels on the floor if you can get access - ie on ramps.
    Jan 2012
    N.Ireland
    Quote Originally Posted by alcutler View Post
    ah! Mis-read the original post. I took wheel to mean steering wheel. Got it now. Thanks.
    F
    Regular Member CH-VECTRA-ELITE's Avatar
    Frimley
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 140000
    Where did you get the parts from, VX??? mine vibrates at 80mph but ok at all other speeds
  1. Vibration through steering wheel
    By hothatch in forum Engine & Drivetrain
    Last Post: 1st December 2012, 20:58
  2. Steering wheel vibration/wobble
    By gibbon7000 in forum Suspension, Wheels & Brakes
    Last Post: 24th September 2010, 20:23
  3. steering wheel wobble/vibration
    By trucker in forum Insignia car chat
    Last Post: 3rd June 2010, 21:20
  4. vibration through steering wheel at 70mph
    By stef in forum Introduce yourself.
    Last Post: 2nd March 2009, 10:10
  5. vibration from wheels,steering wheel
    By steve.o in forum Suspension, Wheels & Brakes
    Last Post: 26th March 2007, 01:29
