hi all, as title, just bought a sri steering wheel off ebay and suddenly thought is it smaller than my crappy plastic exclusive one?? and will my airbag go straight on the sri one??
Anyone done this can help?
is your exclusive one a 3 or 4 spoke wheel?
mine swapped over ok exclusive /sri .t50 iirc to remove
just make sure you disconnect your battery and leave it for a good hour or so before hand to make sure you don't set the airbag off!
Thanks for the quick replies.
keith1983....mine is 3 spoke facelift.
bought this one. Bargain i hope.
http://www.ebay.co.uk/itm/3606001090...84.m1497.l2649
There is a How2 about changing the steering wheel.
http://www.vectra-c.com/forum/showth...l-removal-swap
The airbag can also have 1 or 2 connector wires. You need to check yours to find out.
You only need to pop the airbag out to see how many connections, a small flat bladed screwdriver needed.
Torx T50 bit needed to remove the steering wheel.
Missed your last post.
That looks a good choice and a good price too.
It is a lot easier getting one with the same number of spokes.
The audio controls swap over ok, but the bottom cover(s) are different between the 3 spoke and the 4 spoke.
