Results 1 to 10 of 16
Thread: Creaky Dash
    Apr 2012
    Wexford
    Trim : SRI
    Engine : 1.9 150
    Mileage : 146,000
    Default Creaky Dash
    over the last week or 2 the dash in my vectra seems to have developed a creaking, it wasnt in it when i got it just over a month ago (or at least i never noticed it) and first it seemed to start creaking a bit on a back road where the road was rough, but the last day or 2 now it seems to be doing it even on a main road, smooth surface. Its not doing any harm as such but its just one of those things that really annoys you after a while Ive pushed on the dash on every point i can while driving the car to see if the creaking stops but it doesnt, it sounds as if its coming from near the windcsreen area, mabey where the vents are in the centre by the glass but when i press on them it doesnt seem to stop either!!
    Has anyone else had this problem or know the location of the screws or fixings of the dashboard so i could check and try thighten them up mabey?
    May 2011
    Ashby-de-la-Zouch
    Trim : sri nav/Elite
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    Are you sure its not the centre dash vent? Because mine does it from the vent it winds me up! Am going to try double sticky tape see if that helps.
    Apr 2012
    Wexford
    Trim : SRI
    Engine : 1.9 150
    Mileage : 146,000
    well it does sound as if its coming from that area, but i tried pressing on it while driving, although i cant press on it all at once so i might try with a friend pressing on one side of it! I also tried driving with the centre piece removed but still made noise!! I didnt mind it at first but now its starting to really bug me, i have to turn the radio up now to drown it out
    Regular Member pszczo's Avatar
    Apr 2012
    Basingstoke
    Trim : XP2
    Year : 08
    if you will find it what it is ,please let me know , got the same and it drives me crazy !!!!
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    Try the glove box
    Jul 2011
    UK
    Year : 06
    I've done the following and got none now using padded tape I've put it under the dash strip bother sides under the heater panel around the cubby hole around the light switch under footwell qgere the heater vents touch the plastic under the glove box my car now silent just rattles in bit and brakes now
    Regular Member azacbr6's Avatar
    Dec 2010
    chesterfield
    Try wd40/silicone oil in all joints/cracks wherever there are screws. it worked for me in the past, not on a vectra but on other cars. Worth trying because the creaking noise comes from pieces of dashboard rubbing together and the oil will get rid of the noise. Hopefully.
    Apr 2012
    Wexford
    Trim : SRI
    Engine : 1.9 150
    Mileage : 146,000
    Ill try some wd40 around the center vents first as it definitly sounds to be coming from around there, if that doesnt work then ill go at it with the tape i tried pushing on the glovebox aswell and even with it opened, it didnt make any difference!
    Full Member Z80's Avatar
    Apr 2008
    Noumea
    16 Post(s)
    Vehicle : Opel Vectra GTS
    Trim : Elegance
    Engine : 2.2 DTi 16V
    Mileage : 75 000
    Maybe silicone or Teflon grease would be less messy (and stinky) than WD40...
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Quote Originally Posted by marc vectra sri View Post
    What did you need to remove to do all that (not 100% what you did either from reading that )?
  1. Creaky Dash/Interior after Windscreen Change
    By Leemarksmith in forum Vectra C / Signum Car Chat
    Last Post: 10th April 2011, 21:47
  2. Creaky suspension
    By Danialj32 in forum Vectra C / Signum Car Chat
    Last Post: 5th November 2009, 10:33
  3. Creaky doors
    By deanos in forum Vectra C / Signum Car Chat
    Last Post: 18th June 2009, 12:05
  4. Creaky back end !
    Last Post: 12th September 2008, 12:38
  5. Creaky frt end
    By The-Bandit in forum Suspension, Wheels & Brakes
    Last Post: 16th December 2007, 23:03
vectra-c
