I have a design veccy and the headlight adjusment has broken (it keeps my lights pointing down)so my question is can i fix it or get it off another headlight and fit on to the one i currently have ??? And is really peeing me off driving at night naw
Might just be the adjuster has popped out. Take the headlight out (only takes 5 minutes) and remove the panels on the back. You'll work out where the adjuster is when you look inside the panels. I'm guessing you don't have auto leveling lights?
Nope dnt have auto levelerz and its the inside of the headlight it just flops down and its annoying the hell out of me lool
This happened to my headlights it's prob popped off the holder inside the light.
What I did is took the light off and took the bulbs out I did try with my fingers and pull it but the mettle started to cut into my fingers so I ended up getting pliers and got a grip of it and pulled on it and it popped right back onto the holder.
Yep, sounds like the adjuster motor at this stage fella - if you get stuck drop me a pm and we can have a look (since I'm local to you) if you are not sure what you are looking for
Mods : Insignia Washer Jets,Boot & Footwell LEDs,Reverse Cam,Pioneer AVH-3200BT,Pioneer TS-Q172C(front),Alpine MRVT407 V12 Amp,Alpine SBE-1243BR 12" Sub,In Car Freeview TV,Heko Wind Deflectors,Airbox mod,K&N Panel Filter,Irmscher Boot Spoiler,Angel Eyes, 50W 5K HIDs, 30mm Lo lowering springs, Eyebrows,17" Fox Alloys,Powerflow Stainless Steel dual exhaust. Winner-Best I.C.E-Heritage Centre Meet 2013
Dave thanks alot mate il pm you jus wanted it sorted rather see where im going at night !
mine has been doing this too, up/down is fine but left/right does nothing on the one side
check see if its popped off the holder inside how you will know is if the inside moves it has popped off and will need popped back on.
