Thread: 1.9cdti turbo
    wales
    Default 1.9cdti turbo
    Hi guys,
    I'm new to posting so here goes.
    I have a 2005 1.9cdti 120 sri vectra and its had a whining turbo now for about 2 years but after its MOT yesterday now sounds really bad and is getting a little underpowered if reved hard.
    I'm looking to change the turbo out but do it as cheap as possible due it only being a runner around and being poor, lol.
    I can get a secondhand turbo for £120 of a 70,000 mile car.
    My question is, are the turbos of a 1.9cdti 120 preface lift model all the same? is it just a simple swap, like for like?
    Cheers Guys
    Feb 2013
    Redditch
    Trim : SRI
    its not really worth getting a second hand turbo but if you do check for play in the shafts as this can indictate it being worn , check the impellors for damage etc , try go down the reconditioned route as with these you get 12 months guarrantee . the best way to attack a turbo change on z19dth/z19dt's is to go through the front remove bumper , reinforcer and rad pack , drain coolant before removal of rad , then its just a swap over job changing all the gaskets as you go, change the oil filter once you have built it all back up . this isnt a terribly hard job just time consuming
    Jul 2011
    UK
    Year : 06
    hybrid turbo
    Nov 2012
    Derby
    Vehicle : Vectra 1.9 CDTI 120
    Trim : Energy
    Engine : 1.9 8v 120 BHP
    Mileage : 170, 000
    Quote Originally Posted by marc vectra sri View Post
    hybrid turbo
    What's the difference in the two turbos and is an hybrid cheaper ?.
    I plan to strip mine down to clean the VNT mechanism and plan to go in through the front. Mines a 120 too.
    wales
    Are the turbos off all 120 prefacelift models the same then? does the air con rad need to be removed? is the aircon system under pressure?
  1. 1.9cdti(150) turbo
    By spidermonkey in forum Vectra C / Signum Car Chat
    Last Post: 25th September 2011, 19:44
  2. Hybrid Turbo for 1.9CDTI 150
    By GazVXLINE170 in forum Diesel Engine related
    Last Post: 6th April 2011, 23:57
  3. 1.9cdti turbo
    By olblue in forum Engine & Drivetrain
    Last Post: 15th March 2011, 00:40
  4. does your turbo on vec 1.9cdti 150bhp
    By bridge_eee in forum Engine & Drivetrain
    Last Post: 25th September 2010, 20:13
  5. Bigger Turbo - 1.9CDTI (150)
    By Seery_SRI in forum Diesel Engine related
    Last Post: 16th May 2009, 18:52
how to change a turbo on a vectra c 1.9cdti
jahutusvedelik turbo
Vauxhall vectra cdti 120 remove conditioning
where is the turbo on a vauxhall vectra 1.9 cdti
