Thread: 245 45 19 on snowflakes?
    Regular Member Angel1368's Avatar
    Mar 2012
    liverpool
    34 Post(s)
    Trim : VXR
    Engine : 2.8 V6 turbo
    Mileage : 44,000
    Default 245 45 19 on snowflakes?
    Hi all i know they should be 235 35 19 on snowies but been offered a set of the above for stupid low price will they be ok?
    Regular Member Hummelshøj's Avatar
    Aug 2009
    Denmark, Kolind
    Vehicle : Vectra C OPC Estate
    Trim : OPC / VXR
    Engine : Z28NET
    I´m affraid that they will not fit in the arches at all.. The sidewall on those tires are to high..
    Regular Member mike.'s Avatar
    Oct 2012
    peterborough
    Trim : SRi NAV
    Engine : 1.9 CDTi 120
    far too big for a vec
    Mar 2012
    liverpool
    34 Post(s)
    Trim : VXR
    Mileage : 44,000
    so not even for a short fix? someone has kindly slashed my 4 tyres
    Regular Member rockafella8587's Avatar
    Nov 2011
    Akrotiri, Cyprus
    235/35/19: Rolling circumference - 2036mm, Diameter - 648mm
    245/45/19: Rolling circumference - 2212mm, Diameter - 704mm
    Your speedo will read 8.6% less than your actual speed.
    Just got that from here http://www.autopartuk.com/tyre-calculator/
    Mar 2012
    liverpool
    34 Post(s)
    Trim : VXR
    Mileage : 44,000
    thanks for the info bud i know its far from perfect but they ill do for now?
    Nov 2011
    Akrotiri, Cyprus
    No problem I think the issue may be that they might rub on the inner wheel arch. Is there a way you can test fit them and turn the wheels lock to lock?
    Full Member RichM's Avatar
    St Clears, S Wales
    83 Post(s)
    Vehicle : Monaro
    Trim : VXR
    Engine : 6.0 LS2
    They're going to rub like crazy, I'm sure of it. Mine are 245/35/19 and they are very close at full lock.
    Mar 2012
    liverpool
    34 Post(s)
    Trim : VXR
    Mileage : 44,000
    will they look stupid aswell?
    Regular Member dilan's Avatar
    Aug 2009
    dudley, west midlands
    Sorry to hijack the thread guys,, has anyone fitted 235/40/19 tyres instead of the 35 profile, just wandering if the extra width of a 40 profile would offer a bit more cushioning .... Curious
    Sent from my iPhone using Forum Runner
  1. Snowflakes!
    By 3.2_V6_VXR in forum Parts for sale
    Last Post: 18th October 2008, 19:15
  2. Snowflakes!
    By 3.2_V6_VXR in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 5th June 2008, 22:36
  3. snowflakes.
    By VEC-MAN in forum Vectra C / Signum Car Chat
    Last Post: 8th February 2008, 21:55
will 245 45 19 tyres fit on vectra c
