Thread: Vectra c steering rack dashboard steering wheel
    Sep 2009
    Consett County Durham
    Vehicle : 52 Vectra c LS 1.8
    Default Vectra c steering rack dashboard steering wheel
    Hi I have had my steering rack and track rod ends replaced on my 52 plate Vectra c for its Mot which it has passed.Problem is the steering wheel has lit up on the dashboard the mechanic says it just needs to be on the computer to remove this,i am not sure about this as when driving it seems a bit slightly stiff any ideas about this.Regards Martin.
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Have they done wheel alignment properly
    it may be lit up because of the steering angle sensor.
    have you checked fluid?
    Jan 2013
    Peterborough
    Vehicle : Vectra edition 100
    Engine : 2.0T
    Mileage : 82000
    i got to get mine done for the next MOT, how much did it set you back?
    Administrator plasma's Avatar
    On the Forum
    579 Post(s)
    Engine : 150
    Mileage : 74000
    I can recommend somewhere local to you if you like
    Regular Member Keif's Avatar
    In the Garage
    Quote Originally Posted by Critch View Post
    This is your problem.
    Check (and top up) your Power Steering fluid, the steering wheel warning light will go out and you'll get your steering back.
    There's a How to in the Technical Section to help you.
    Sep 2009
    i got to get mine done for the next MOT, how much did it set you back? I have a friend mechanic he got it for £140 vat included, track rod ends £10 each.
  1. Replies: 6
    Last Post: 13th March 2011, 10:47
  2. Taking out dashboard and steering wheel air bag
    By mik sri in forum Introduce yourself.
    Last Post: 14th March 2009, 09:27
  3. Vectra C Steering Rack Help
    By goggins1234 in forum Engine & Drivetrain
    Last Post: 18th June 2008, 13:20
  4. where can i buy a vectra c steering rack
    By ozzye in forum Suspension, Wheels & Brakes
    Last Post: 23rd March 2007, 19:43
vectra c steering wheel on dash
