Thread: Vectra c H/lights
    Jan 2013
    N.Irelandbt71 7EP
    Exclamation Vectra c H/lights
    Hi! Guys this is my first time on this site.
    I have a 2003 vectra c 2.2 dti with xenon headlights.2 questions can this vehicle be converted
    to ordinary lights as i am having problems with self levelling light on in dash.This brings me to q2
    took it to my local Vauxhall dealer and put on computer coming up is low voltage to front/rear
    level sensor. Put new sensor on front but still the same.Checked wiring and no wires broke.Could it
    be the Light Control Module on N/S light.Any help appreciated
    Regards
    Raymond
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    Engine : 1.6T SIDI Petrol
    probably the motor in the light itself has failed which you can change.. cheaper to do that..
    Jan 2013
    N.Irelandbt71 7EP
    Hi! vax garage override the system with computer and lights rising/lowering with computer
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    so they changed the level sensor on the front, did they change the rear as well? They did and test and had the lights adjust themselves ok which supposedly says they are functioning correctly.. then they let you drive away without testing further to ascertain the problem?
    You do not want normal lights on your car trust me, they are very weak, if you have xenons then stick with them. go to an auto electrician if necessary as the dealers do not really know what they are doing, all they do is plug in the tech2 then change one part after another until they eventually sort it or you are bankrupt.
    Jan 2013
    N.Irelandbt71 7EP
    didnt change rear just want to get car through MOT then sell it with any lights
  1. Brighter Lights for side lights, Vectra SRI150
    By 150_SRI in forum Vectra C / Signum Car Chat
    Last Post: 13th July 2011, 23:50
  2. vectra fog lights
    By octoman in forum Electrical & ICE (including SatNav)
    Last Post: 4th July 2011, 01:07
  3. Vectra lights
    By Philhammond2004 in forum Vectra C / Signum Car Chat
    Last Post: 19th May 2011, 11:00
  4. Vectra Sri Lights
    By Philhammond2004 in forum General Chat
    Last Post: 18th May 2011, 23:39
  5. vectra c lights
    By alan66 in forum Electrical & ICE (including SatNav)
    Last Post: 18th May 2009, 16:52
